Hackaday.io Hackaday.io
Sign up Log in
Parametric Keypad
I could not find a programmable keypad that I liked so I decided to design and build one of my own to use as a pendant for my x-carve cnc.
justin-coleJustin Cole
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
4 followers
  • Description
  • Details
  • Files 0
  • Components 6
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
437
0
4
2
Team (1)
  • justin-coleJustin Cole
Join this project's team
  • Onshape
hardware
ongoing project
CNC oNSHAPE Cad pendant arduino 3D Print
This project was created on 11/05/2017 and last updated 9 years ago.
Description
This is a programmable keypad designed in Onshape. The parts are 3d printable and switches and keycaps can be found at many different sites. It uses an Arduino Micro as the controller since it can act as an HID device.
Components
  • 1 × Arduino Micro
  • 1 × Cherry MX Switch 1 - 20 depending on the keypad size
  • 1 × Keycaps I used DSA so that they are the same shape all of the keypad.
  • 1 × Cover Plate 3d printed or CNC'd
  • 1 × Key switch plate 3d Printed or CNC'd
View all 6 components
Project Logs
Collapse
  • 3d Prints and test fits
    Justin Cole • 11/05/2017 at 20:59 • 0 comments
View project log
Log In/Sign up to comment
Sign up with Github
OR
Hackaday Prize 2019
Teach elementary and middle-school students about robotics with a DIY battle bots kit.
Project Owner Contributor
Educational Battle Bots
misty-lackieMisty Lackie
24:1 Reduction 3D Printed Dual Cycloidal Gearbox with Backlash mitigation with three split housings coupled with BLDC Motor
Anti-Backlash 3D Printed Cycloidal BLDC Actuator
paul-gouldPaul Gould
I have repaired and hacked more than a few Sybian's over the last few years and decided it was time to design and build my own.
3D Printed Vibrating Saddle
boris-van-galvinBoris van Galvin
Using an old frame I bought a while back and the newer parts on the Flite Test website to build my very first FPV drone
Flite Test Gremlin FPV Drone
jibrilJibril
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Parametric Keypad", please tell us the reason.
Send message
Remove Member
