#include "cambadge.h"
#include "globals.h"
// C5
#define CLK PMADDR & 8 ? 1 : 0
#define CLK_LOW PMADDR = PMADDR&~8
#define CLK_HIGH PMADDR = PMADDR | 8
// B4
#define OUT LATBbits.LATB4 ? 1 : 0
#define OUT_LOW LATBbits.LATB4 = 0
#define OUT_HIGH LATBbits.LATB4 = 1
// A2
#define IN PORTAbits.RA2 ? 1 : 0
#define DELAY_US 120
#define PACKET_SIZE 640u
#define GBP_MEM_SIZE 7680u
unsigned int GBSendByte(unsigned int b);
unsigned long GBSendPacket(unsigned int command, unsigned long size);
// Game Boy Printer Commands
#define GBC_INITIALIZE 0x01
#define GBC_PRINT 0x02
#define GBC_TRANSFER 0x04
#define GBC_REPORT 0x0F
char* gbprint(unsigned int action)
// MAGIC CMD RLE SZLO SZHI DATA(640) CHKLO CHKHI STATUS STATUS
// 88 33 01 00 00 00 01 00 00 00
unsigned int init[] = {0x88, 0x33, 0x01, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00};
switch(action) {
case act_name : return("PRINT_BOY");
case act_help : return("Digital to paper yo");
case act_init : return(0); // run once at powerup
case act_powerdown : return(0); // run before powerdown
case act_start : return(0); // called when app is selected
if (action!=act_poll) return(0);
if(!tick) return(0);
size_t init_length = sizeof(init)/sizeof(init[0]);
unsigned int reply[] = {0x00, 0x00};
unsigned int i = 0;
while(i < init_length) {
unsigned int byte = init[i];
printf(cls whi top "Length %d / %d\n", i, init_length);
printf(red " %#02x\n", byte);
unsigned int j = 7;
while(j>0) {
CLK_LOW;
delayus(DELAY_US/4);
if (byte & (1<j)) {
OUT_HIGH;
} else {
OUT_LOW;
CLK_HIGH;
delayus(DELAY_US/2);
if (i == init_length-2) {
reply[0] = reply[0] | (IN << j);
} else if (i == init_length-1) {
reply[1] = reply[1] | (IN << j);
j--;
while (!(butpress & powerbut)) {
printf(bot grn "Reply: %#02x %#02x", reply[0], reply[1]);
printf(grn " exit!");
return("");
jonathan
jobinpthomas1
jareklupinski
davedarko
Thanks Mike! You helped a bunch. Currently scoping out some more output/input
