Embedded LEDs work
A project log for Silly PCB Designs
Abusing OSHpark for Fun!
jasmohJasMoH • 11/29/2017 at 17:02•4 Comments
As they arrived from Fab. The hole grid is weirdly shimmery and would be visually interesting in its own right.
After coring out the body with a 20g hypodermic needle
Populated
Lit
JasMoH wrote 11/30/2017 at 19:23 • point
That's what I was thinking about when I made it. Right angle mount LEDs exist already; see https://www.digikey.com/product-detail/en/kingbright/APA2106SYCK/754-1061-2-ND/1747459
I bring this up because if you want, say, a ring light that illuminates inward, these would be an easier way to do that.
I really like how much these resemble fairy lights or fire-flies if you mask the LED itself so it only sends light through the PCB. it very much reminds me of fireflies. I'll post some pics.
moosepr wrote 11/30/2017 at 09:11 • point
I have seen the future!! And it is glowing PCB's!!! Dam interesting idea
oshpark wrote 11/30/2017 at 02:35 • point
Wow, that's tiny!
Bastiaan wrote 11/29/2017 at 18:30 • point
It could be an interesting way to illuminate something else in between a number of leds mounted these way around that. Some sort of illumination from the inside of the pcb as light shines throughout the material.
