1Get the new app to appear on the badge, fast instructions
Add an app the easy way
- Right click on the demo_app file and select copy
- Right click on "Source Files" and select paste
- Change name of new file to name of main function of app, i.e. "basicbadge"
- Open that file and paste code for app
- Add references to it in the appmap file. See example.
- If hex won't compile, close and then open the project again.
alternatively you can download the files and import them in to the project with your prefered method.
