I won't lie, this feels messy. This currently features 5 animations, where 2 of them are just "played accelerating" .
Some things I'm not happy with:
- the button does not work within the animations, so you need to push the button until the animation cycle is over
#include <avr/sleep.h>
#define nop() asm volatile("nop")
boolean leds_on = true;
byte badly_programmed_counter = 0;
byte animation_counter_max = 5;
byte animation_counter = 0;
// we need two frames with 8 bits for 12 LEDs
byte frame1 = 0;
byte frame2 = 0;
// animation where every third LED is glowing
// I could shift that continuosly and drop 4 bytes
const byte three_apart_length = 6;
const byte three_apart[three_apart_length] PROGMEM = {
0b10010010, 0b01000000,
0b01001001, 0b00100000,
0b00100100, 0b10010000,
// this one is huge
// is there a math function to do that instead?
const byte updown_length = 14;
const byte updown[updown_length] PROGMEM = {
0b00100000, 0b00000000,
0b01010000, 0b00000000,
0b10001000, 0b00000000,
0b00000100, 0b00010000,
0b00000010, 0b00100000,
0b00000001, 0b01000000,
0b00000000, 0b10000000,
// that's just blinking each led
// maybe inverting the data bitwise does the trick
const byte two_apart_length = 4;
const byte two_apart[two_apart_length] PROGMEM = {
0b10101010, 0b10100000,
0b01010101, 0b01010000,
// should have taken a switch, sleep stuff is huge
ISR(INT0_vect) {
sleep_disable();
leds_on = true;
void setup()
// this is for the button setup
PORTB |= (1 << PB1);
DDRB &= ~(1 << PB1);
shutdown_chip();
void loop()
if (leds_on)
cli();
leds_on = false;
// I call it that, because the millis stuff
// and the interrupts collided and broke
// fancy way of checking the button state
if (!(PINB & (1 << PB1)))
badly_programmed_counter++;
my_100ms_delay();
// check if button was released before time
// so animation index can be incremented
// maybe a modulo with animation_counter_max
// safes space
if ( (PINB & (1 << PB1)) )
animation_counter++;
if (animation_counter == animation_counter_max)
charlie(animation_counter);
// calling a function instead of writing it down
// 5 times helps already
for (byte b = 0; b < 5; b++) my_100ms_delay();
if (badly_programmed_counter >= 7)
// blink when shutdown is immanent
for (byte b = 0; b < 5; b++) blip();
shutdown_chip();
else
animate_leds();
// this is probably already at it's best
void charlie (byte var) {
leds_off();
switch (var) {
case 0: // 1
DDRB |= (1 << PB0) | (1 << PB2); // output
PORTB |= (1 << PB0); // HIGH
break;
case 1: // 2
PORTB |= (1 << PB2); // HIGH
break;
case 2: // 3
DDRB |= (1 << PB2) | (1 << PB3); // output
break;
case 3: // 4
PORTB |= (1 << PB3); // HIGH
break;
case 4: // 5
DDRB |= (1 << PB3) | (1 << PB4); // output
break;
case 5: // 6
PORTB |= (1 << PB4); // HIGH
break;
case 6: // 7
DDRB |= (1 << PB0) | (1 << PB3); // output
break;
case 7: // 8
break;
case 8: // 9
DDRB |= (1 << PB2) | (1 << PB4); // output
break;
case 9: // 10
break;
case 10: // 11
DDRB |= (1 << PB0) | (1 << PB4); // output
break;
case 11: // 12
break;
default:
nop();
void shutdown_chip()
leds_off();
/* Clear WDRF in MCUSR */
MCUSR &= ~(1 << WDRF);
/* Write logical one to WDCE and WDE */
/* Keep old prescaler setting to prevent unintentional time-out */
WDTCR |= (1 << WDCE) | (1 << WDE);
/* Turn off WDT */
WDTCR = 0x00;
ADCSRA &= ~(1 << ADEN); // turn off adc
GIMSK |= (1 << INT0);
GIMSK |= (1 << PCIE);
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_enable();
sei(); // Enable global interrupts
sleep_cpu();
sleep_disable();
void animate_leds()
switch (animation_counter)
case 0:
animate_frames(
three_apart_length,
three_apart,
512
break;
case 1:
for (byte acc_counter = 1; acc_counter < 64; acc_counter += 2)
animate_frames(
three_apart_length,
three_apart,
acc_counter * 8
break;
case 2:
animate_frames(
updown_length,
updown,
512
break;
case 3:
animate_frames(
two_apart_length,
two_apart,
2048
break;
case 4:
animate_frames(
updown_length,
updown,
(63-acc_counter) * 4
break;
default:
leds_off();
break;
void animate_frames(
byte animation_length,
const byte* animation_array,
uint16_t frame_duration
for (byte i = 0; i < animation_length; i += 2)
// save the last time you blinked the LED
frame1 = pgm_read_byte_near(animation_array + i);
frame2 = pgm_read_byte_near(animation_array + i + 1);
show_frame(frame_duration);
// this just looks ugly, but needs to be done
// for loop through frame bytes to set the LEDs with
// the charlie plex function
void show_frame(uint16_t byteframe_length)
for (uint16_t j = 0; j < byteframe_length; j++)
//iterate through bit mask
for (byte i = 0; i < 12; i++)
// if bitwise AND resolves to true
if (
i < 8 &&
1 << i & frame1
i > 7 &&
1 << (i - 4) & frame2
charlie(i);
else
charlie(255);
void leds_off()
DDRB &= ~(0b00011101);
PORTB &= ~(0b00011101);
void blip()
charlie(11);
// delay(100);
my_100ms_delay();
charlie(255);
// delay(100);
my_100ms_delay();
void my_100ms_delay()
for (uint32_t i=0;i<40000;i++) nop();
void charlie (byte var){ }
Not sure how smart the compiler is. You could possibly to use var to index 2 constant uint8_t arrays (in program space) to set the values of DDRB and PORTB instead of a switch(). The arrays takes up 24 bytes, so there are some potential saving there
Should do a bound check for the index range.
Maybe use a pair of lookup tables for the assignments to DDRB and PORTB in the charlie function?
save space
Yikes. I knew something looked off thanks.
I only looked over your code quite quickly but some thoughts:
- Are you using the Timer0 anywhere? I did not see it. If that timer is unused it could be handy for all that timing stuff. Also a timer needs mostly only code for setup,
- Polling on the switch is in general a good idea, but using an interrupt (e.g. the - as far i can see - unuesed pin-changed interrupt, could make it more independent from the rest)
Just some ideas... But it would be a nice challenge to improve that a little bit. I would also guess that the library sleep function could get minimized a little bit. Somehow I now would relay like to compile that now and have a look at the assembler listing, but too late...
I wasn't able to recover the Timer from the interrupt routine, but that might safe some loops and whiles on the way.
I also was messing up the interrupts big time :D
Would it help to make an animations struct to pass by ref to animate_frames()?
struct animation
const byte length;
const byte *data;
const int16_t duration;
you could have an array of these structs indexed by animation_counter. It saves the repetitive code in the switch statement inside animate_leds(). Not sure if it ends up being a net space win.
There is the problem of the accelerating ones, too. You could put a function pointer in the struct to parametrize the acceleration function, but I'm not sure how much space this ends up taking.
Or, you could parameterize accelerations by with a formula:
(a*acc_counter + b) * c + duration
with (a = -1, b = 63, c = 4) or (a = 1, b = 0, c = 8) or (a = 0, b = 0, c = 0) you can get the current functionality. Again, I don't know if this would end up being smaller than the inline code version.
interesting idea :) I thought about a joined animations array before that. That might safe a byte or two but then I'd need to store a start point then. So win some lose some.
