I originally designed it for needing a light on what I was working on at the time. After searching the web for DIY lamps, I found Mr. Useful's popsicle led lamp. His Video is below. I then thought I could design my own in Cad. So that is what I did. I then printed the parts out and assembled using some nuts, bolts and magnets. I hot glued the led in place and then super glued some tinfoil on the inside of the lampshade. Installed the electronics and Valla. I used magnets on the top and bottom parts to have easy access. Inside the bottom, you could hold spare coin batteries. Or add some weight to it.
OddDavis
Niko
Lyon
Next Builder
Pat Mutia
