Lafayette reconnected, neutral soldered onto case
01/28/2018 at 16:46 • 0 commentsI opened the Lafayette, as it was working, but very weak signal and very noisy. Since the connector to the aluminium shaft was previously hacked and chewed, I pulled it out and soldered a brand new connector inside the metal case (discarding the plastic casing). It now correctly has a shielded three pin connector, however I soldered the neutral pin to the case, since it was a two pin before.
The signal is much stronger now, but still very noisy. So I might have to come up with a different solution.
Red paint turned brown
12/03/2017 at 09:44 • 0 commentsOk so, I took the FatBoy apart, and inside is a lot of brown powder.. First I thought it is rust, but then I realised it is paint. Researching, I found out that the microphone I have is one of the first Fat Boys released. They had the interior mesh (made of silk) painted in red, (which apparently turned brown after all these years..). The later models had a switch at the back (to select frequency empedence) and later again they released a much smaller FatBoy microphone which then became one of the most widely used microphones in radio broadcast etc. So I can safely date this mike pre 1946, which is when they fitted the switch.
