This project was like a small version of, an imagination turned into reality.
The whole Project Has three folds:
1. A static robot:-
This part will contain some ready to serve food items like biscuits, Snacks, dry fruits, Health supplements in the form of biscuits, etc in each separate container and the plates are also stacked in this part.
It can serve any of the items contained in it, as per the order placed through a smart phone application.
2. A movable Robot:-
This is a simple path following robot which has a tray mounted over it.
Initially this bot is placed in front of the Static Robot, (position being traced using IR sensors, and will be further upgraded with RFID tags), the plates served by the static robot is placed over the tray. The Smart Phone app enables user to select the location(room no.) where he wants to be served. This data, fetched by the static robot(currently over Bluetooth), and it sends the location data to the movable bot.
The movable bot after receiving the plate follows the path which leads to the targeted location as per configuration.
3. A smartphone application:-
Features:
- The prototype we made, communicates over Bluetooth protocol through our application. This will be further upgraded to WiFi to increase the range of application.
- The app has a function of setting remainder and alarm to get delivery of food at particular time at particular location.
- User can configure their servings (i.e amount of snacks and number of plates) whatever and wherever they need and this info is sent to the static bot.
Here is the Video of working of the prototype
#Phase 1 complete
#Full demonstration
Tanuj Kashyap
GOAT INDUSTRIES
Wei Wang
Dejan
Will Donaldson
