1Pre Requisites for understanding the Project Built
One need to be familiar with
*Arduino IDE,
*Building basic apps using ai2.
*basic sensor modules, etc -
2Starting with the Shape:
Shape can be anything as per the choice of make.
*The shape of the container is as shown in this image![]()
3Container Opening and closing mechanism
4Plating Pushing Mechanism
*Use a servo motor (like tower pro, MG995, ) to push the plate in a controlled way.
5Bluetooth Module, HC 05
* Use a separate source for powering the Bluetooth Module HC 05.
6Building the app
* For easy build, go for MIT app inventor 2.
* One can prefer other resources as per convenience. -
7The Movable bot
This is a simple Line follower, And obstacle avoidance robot With a tray type structure mounted over it
8The Software Files
Tanuj Kashyap
