status 1
01/08/2018 at 21:45 • 0 comments -
status 2
01/08/2018 at 21:44 • 0 commentsPerfect candidate to set horse in motion waits for neodymium magic rocks from behind Great Wall.
Winter came, rocks don't.
orginal photo stack by Master croped and aligned
oshpark board visualisation
all that sitting on magnet bearing with halbach array eddy currents stabilizer, on oshpark self supporting pcb, in glass dome, in a fricking vacuum.
10Ohm coil pulsed from nano timer or msp430 with DRV5032 hall sensor for initial startup.
with synchronized, pulsed led for stroboscopic illusion
assumed power consumption - under 1uA
dome - check, coil - check, drv/msp - check, great support from oshpark - double check
messenger with goods from silk road - absent ---> project delay, yet still ongoing
