1Upload the Arduino sketch
First you need to install the Arduino IDE. Then you have to install the library for Esp8266
Here is a good tutorial how to setup the Arduinio IDE for programming the Esp8266.
After opening the sketch with the Arduino IDE you have to do some settings depending to you local WIFI before uploading:
//For a faster connecting/switching we use a static ip adress: IPAddress gateway(192,168,178,1); //ip of you local wifi router where the hue bridge is connected IPAddress ip(192, 168, 178, 216); //ip of your switch, be aware of using a high adress in the range of 200-250 that is not used for other devices IPAddress subnet(255,255,255,0); int light = 2; // the number of your light that is switched const char hueHubIP[] = "192.168.178.57"; // the ip adress of the hue bridge const char hueUsername[] = "hue bridge username" //username the hue bridge const int hueHubPort = 80; always "80" const char ssid[] = "SSID"; // network SSID (name) const char pass[] = "password"; // network passwordyou have to create an authorized username in the hue bridge, look at this tutorial
2Step 2
STLs for the remote control are uploaded, I use normal print settings with an infill of 30% and 0.2mm layer height
The knob is also printed so you can use the reset button for action and don't has to use an extra button.
Use skirt and brim for the knob because the object is very small
3Some additional Infos and assembly video
Be sure to pre-charge the cap before connecting to wemos because the Esp8266 immediately start to make a wifi connection
after reset/connect power.
to save energy disconnect pin 4 and 16 of uart-ic and remove the voltage regulator, please note that it's no longer possible to program the wemos via USB !!
Feel free to ask your questions
Gelstronic
