1How to Use ALio
ALio comes with a unique and different orientation NON-through-hole BUS pad designed to be used for SMD components or routing circuits as double layer.
Point-to-point wiring is easy with ALio, just a blob of solder does the trick. In addition, the double layer bus lets you route as circuits as if they were on a double-layer PCB, so you can forget about using wire jumpers. This is great for quickly prototyping stackable circuits.
2MCU Break Out Board
ALio MCU Break Out Board is not like ordinary one. It is designed to fit TQFP44, TQFP32, MLF32, and SOIC IC packages on one side. On the other side, it has a unique pad to fit SMD components for your microcontroller’s minimum requirements, such as capacitors, inductors, crystals, resistors, or LEDs. It also has a mini-USB/micro-USB pad, so you can use it as a stand-alone microcontroller board.
3Yay it is OPEN SOURCE !!
Yes we love open source project. Currently we are designing the final revision, but if you want current version you can message me.
arief ibrahim adha
