Quick Tour Video:
Operation phase 1:
Operation phase 2:
Operation phase 3:
Circuit Diagram:
Circuit operation details:
Magnet / Electromagnet / Hall sensor:
IMPORTANT:
1) electromagnet north pole pointing UP
2) pendulum north pole pointing DOWN
3) hall sensor branded side UP
Main Components:
Hall sensor: UGN-3503-U
IC1: LM358N ( dual OP amp )
IC2: CD4001B (quad cmos nor gate )
FET1: IRFD-120( n-channel power mosfet )
Video:
Images:
SimpleTronic
hIOTron
Magmabow
Edward
Rasmus Ljungmann Pedersen
Hi! I built this circuit according to your circuit diagram. The halls sensor detects the magnet and generates a pulse which is present in Pin 1 of the CD4001. But there is no pulse coming out from pin 3 of the CD4001 and so the rest of the circuit beyond this point is not working. I already double checked all the physical points of the circuit board to be sure it was not a mechanical failure. Then I also tested your circuit diagram in a simulator and came up with the same non-functioning result. I cant understand why the project is not working here but it does work in your video. Can you offer me some advice please?
