LCD Set up
12/27/2017 at 14:08 • 0 commentsOKAY, now that we have the raspberry set up, we can star the assemble of parts.
Let's make the LCD work!
First thing that we need is a adapt board ( its on components list), so we can solder every pin on 40 pin connector to the 40 pin GPIO on raspberry.
Now we can start solder the pins, the schematic is this:
The hard part is the backlight circuit, because its not a simple step up, you can use this circuit:
I have a different circuit here, and i prefer to use it.
Now you just need to enable this lcd in raspberry.
First you need to download this DPI file and paste on boot partition of SD card.
and edit config.txt also in boot partition, you need to put this:
# Disable spi and i2c, we need these pins. dtparam=spi=off dtparam=i2c_arm=off # Set screen size and any overscan required overscan_left=0 overscan_right=0 overscan_top=0 overscan_bottom=0 framebuffer_width=480 framebuffer_height=272 # enable the DPI display enable_dpi_lcd=1 display_default_lcd=1 # set up the size to 480x272 dpi_group=2 dpi_mode=87 # set up the hsync/vsync/clock polarity and format dpi_output_format=520197 # set up the size to 480x272 hdmi_timings=480 0 40 48 88 272 0 13 3 32 0 0 0 60 0 32000000 3Now just reboot.
And that's it.
Removing what we don't need
12/26/2017 at 15:00 • 0 commentsThe first thing that i do was removing Ethernet, GPIO headers and the two USB hosts, be careful doing that, if you heat too much you can break the circuit line in board, it's a patiently job.
Calebe94
