Features:
- Size: 35 x 26 x 8mm
- ATtiny85 Microcontroller with Micronucleus USB-bootloader.
- CR2032 coin cell holder on the back (can run for weeks or even months when using the micro's sleep functions)
- Transistor (NPN in current sink configuration) for switching larger currents
- All peripherals wired so the impact is minimal if you want to connect other devices
- Micro USB connector for power and uploading firmware
- All micro pins and GND and VCC broken out on SMT pads
- 4 mounting holes (3mm) for easy mounting
User input
- Tact switch
- SPST slide switch
- Potentiometer (100K)
User output
- Piezo buzzer
- Bright LED
To be honest, I can't get the bootloader to work properly (it freezes the USB-hub of my MacBook Pro sometimes) and this is a little above my head as well. I'm not sure if this is a software or hardware issue.
I can imagine this being a really nice sub-$10 starter-board for a lot of people (you could essentially use them as throwies!) but that would require perfect operation and meticulous documentation, application examples etc.
Right now, I don't have time to develop this project further; if someone wants to pick this up, or create something similar, feel free to do so.
Gregor
Ella Jameson
Patrick
ajlitt
The bootloader is programmed by ISP; after that, USB programming works. It just crashes my MacBook Pro's keyboard (USB hub) sometimes :)
