Motivation
This project starts as an entry for the Coin Cell Challenge, but I hope it will outlive it.
I enjoy microcontroller projects and geocaching. Let's make something that will be fun not only for me, but also for others!
Goal
The basic idea is to make a beacon that periodically transmits a number. This number will be used a password for a virtual geocache.
The device should be small and easy to hide. It should last a year on a single battery. The battery must be replaceable. It will be placed outside, so it must be weather-resistant (rain, snow, ice, direct sunlight, temperatures -20°C to +60°C). Transmission must have a broadcast range of at least 20m (up to 50m if possible). It should follow a well documented protocol. The number should be hard to guess and contain a checksum.
Construction of a receiver will be left to the geocacher, but example code and schematic should be included
piotrb5e3
Elliot Williams
Glenn.Kubota (gee.k)
Stephan Walter
Thanks for that! It's equally important to know what won't work on a coin cell.
