Ever since I have my own company I wanted to have a PCB business card. What not add an OLED display to it?
play.gifGraphics Interchange Format - 1.66 MB - 12/30/2017 at 19:31 |
I know adding holes to a PCB raises costs. Cutouts for the display, switches and the battery (moved to the edge for insertion/ removal) could make for a super-thin build. Switch to a CR2016 and you get even thinner. The display could be sandwiched between two clear stickers for durability. The hardest part I see would be sourcing a mid-board battery holder. Just more V2 options. The new ATTiny1607 has micro-power and some more IO at a lower price point (i'm seeing sleep with a cap-sense wake ISR). This build is still very nice.
These are all valid options, but keep in mind that the unpopulated board is my default business card. Real prospects get the populated version. For the unpopulated version is better to have a "solid" version. :)
What Are you selling? We definitely have to meet Michael! =)
Don't know much about electronics, but could you add 2 more buttons or is there not enough pins on the chip? Something like those 99-in-1 brick games from the 90s would be fun! Also does it work on 128x64 OLED?
I used all the available pins. There are some tricks to add more. Or I could switch to the ATTINY84 which has a few more pins. The biggest issue is memory. I wrote a blogpost about this if you are interested: http://michaelteeuw.nl/post/164184894587/electrocard-part-3-writing-the-software
Is there any way you can post the Kicad footprint and 3D model for the SSD1306 128x32 Oled display? I'm inspired by your project and would like to try and create my own.
Mind if I ask how much this costs? I'm building an interactive business card at the moment myself, but I'm hesitant to do too much due to the cost.
The PCB itself is about $1 a piece. When you add all the components, it's about $8 total. I mostly used components sourced from AliExpress. It's a hell of al to cheaper than any other marketing campaign, an it's sure as hell effective: people don't throw away this card, and tend to show it to others (coworkers and business contacts).
Wow, that screen looks really great. Nice job on this project!
Nice business card. A version with a hole for a lanyard would make a nice conference badge too!
Chris Wheeler
Arnab Kumar Das
Saul
Antti Lukats
This one of the best and unique ideas here on this forum and I support you to continuo working on this amazing idea I am also working on a very unique business guide idea you can see here.
