The Software bit...
01/06/2018 at 07:45 • 0 commentsThis is not a super elaborate code that controls the universe and everything.
Instead it's just a very simple piece of code that allows driving a display, debouncing a switch, reading two potentiometers, and drive a relay. That's it.
I use busy waiting to execute the read potentiometer values and I use very simple line drawing to visualize the pulse pattern.
I divided the welding process into two steps:
- Pre-welding the material to heat it up, make it soft and establish excellent conductivity between all materials to be welded
- Welding the material together with a potentially longer pulse.
During my initial tests and from what I have read online in several articles, the typical pre weld time is around 50 ms and the typical weld time is around 100 ms. I used this as a base line since most people don't seem to weld with 1750 Watts. I wanted to be able to adjust my welding times between 25 ms and 275 ms by adjusting two potentiometers. I also added a cooldown time in between the two weld actions of 250 ms. That's a pure guess and should have been adjustable with another potentiometer as well but I didn't see the immediate need for it. If you need it, please add a third pot to the code and to your welder. I don't think it's necessary for making battery packs.
#include <Adafruit_GFX.h> // Core graphics library #include <Adafruit_ST7735.h> // Hardware-specific library #include <SPI.h> // For the breakout, you can use any 2 or 3 pins // These pins will also work for the 1.8" TFT shield #define TFT_CS 10 #define TFT_RST 9 #define TFT_DC 8 #define TFT_SCLK 13 #define TFT_MOSI 11 #define MINWELDTIME 25 #define MAXWELDTIME 250 #define COOLDOWNTIME 250 #define ADCRESOLUTION 1023 #define GRAPHDIVIDER 7 // devides the values for displaying the graph to something that can be displayed // use the hardware SPI pins (for UNO thats sclk = 13 and sid = 11) and pin 10 must be an output. Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST); // constants won't change. They're used here to // set pin numbers: const int buttonPin = 5; // the number of the pushbutton pin const int ledPin = 12; // the number of the LED pin const int relayPin = 2; // the number of the relay pin const int preWeldSensorPin = A0; // the number of the potentiometer ADC pin const int weldSensorPin = A1; // the number of the potentiometer ADC pin // Variables will change: int ledState = LOW; // the current state of the output pin int buttonState; // the current reading from the input pin int lastButtonState = LOW; // the previous reading from the input pin int preWeldSensorValue = 0; // variable to store the value coming from the potentiometer int weldSensorValue = 0; // variable to store the value coming from the potentiometer bool redrawGraph = true; // Did we change the times and need to redraw the graphs? int lastPreWeldTime = 0; // Storage for the previously set weld times int lastWeldTime = 0; // So that we don't run into flickering numbers on the display // the following variables are unsigned long's because the time, measured in miliseconds, // will quickly become a bigger number than can be stored in an int. unsigned long lastDebounceTime = 0; // the last time the output pin was toggled unsigned long debounceDelay = 50; // the debounce time; increase if the output flickers void setup() { pinMode(buttonPin, INPUT); pinMode(ledPin, OUTPUT); pinMode(relayPin, OUTPUT); // set initial LED state digitalWrite(ledPin, ledState); digitalWrite(relayPin, HIGH); Serial.begin(115200); // opens serial port, sets data rate to 115200 bps Serial.println("Spot Welder Version 0.1 - Timo Birnschein - MicroForge 2018"); Serial.println("email: timo.birnschein@microforge.de"); displayInitScreen(); } void loop() { // read the value from the sensor: preWeldSensorValue = analogRead(preWeldSensorPin); weldSensorValue = analogRead(weldSensorPin); // Read analog signal to determine time to weld int preWeldTime = (int)((float)MINWELDTIME + (((float)MAXWELDTIME / (float)ADCRESOLUTION) * (float)preWeldSensorValue)); // Scale 10 bit value to something with an offset int weldTime = (int)((float)MINWELDTIME + (((float)MAXWELDTIME / (float)ADCRESOLUTION) * (float)weldSensorValue)); // Scale 10 bit value to something with an offset // Check for errors if (preWeldTime <= 0) preWeldTime = (float)MINWELDTIME; if (weldTime <= 0) weldTime = (float)MINWELDTIME; if ((preWeldTime > (lastPreWeldTime + 1)) || (preWeldTime < (lastPreWeldTime - 1))) { redrawGraph = true; } if ((weldTime > (lastWeldTime + 1)) || (weldTime < (lastWeldTime - 1))) { redrawGraph = true; } if (redrawGraph == true) { redrawGraph = false; String strBuffer = String(" " + String(lastPreWeldTime) + " ms"); tftPrintText(strBuffer, 0, 50, 1, ST7735_BLACK); strBuffer = String("Pre weld time: " + String(preWeldTime) + " ms"); tftPrintText(strBuffer, 0, 50, 1, ST7735_RED); strBuffer = String(" " + String(lastWeldTime) + " ms"); tftPrintText(strBuffer, 0, 60, 1, ST7735_BLACK); strBuffer = String("Weld time: " + String(weldTime) + " ms"); tftPrintText(strBuffer, 0, 60, 1, ST7735_RED); tft.drawFastHLine(0, 100, 6, ST7735_BLACK); tft.drawFastVLine(5, 80, 20, ST7735_BLACK); tft.drawFastHLine(5, 80, (lastPreWeldTime / GRAPHDIVIDER), ST7735_BLACK); tft.drawFastVLine(5 + (lastPreWeldTime / GRAPHDIVIDER), 80, 20, ST7735_BLACK); tft.drawFastHLine(5 + (lastPreWeldTime / GRAPHDIVIDER), 100, (COOLDOWNTIME / GRAPHDIVIDER) + 1, ST7735_BLACK); tft.drawFastVLine(5 + (lastPreWeldTime / GRAPHDIVIDER) + (COOLDOWNTIME / GRAPHDIVIDER), 80, 20, ST7735_BLACK); tft.drawFastHLine(5 + (lastPreWeldTime / GRAPHDIVIDER) + (COOLDOWNTIME / GRAPHDIVIDER), 80, (lastWeldTime / GRAPHDIVIDER), ST7735_BLACK); tft.drawFastVLine(5 + (lastPreWeldTime / GRAPHDIVIDER) + (COOLDOWNTIME / GRAPHDIVIDER) + (lastWeldTime / GRAPHDIVIDER), 80, 20, ST7735_BLACK); tft.drawFastHLine(5 + (lastPreWeldTime / GRAPHDIVIDER) + (COOLDOWNTIME / GRAPHDIVIDER) + (lastWeldTime / GRAPHDIVIDER), 100, COOLDOWNTIME, ST7735_BLACK); tft.drawFastHLine(0, 100, 6, ST7735_WHITE); tft.drawFastVLine(5, 80, 20, ST7735_WHITE); tft.drawFastHLine(5, 80, (preWeldTime / GRAPHDIVIDER), ST7735_WHITE); tft.drawFastVLine(5 + (preWeldTime / GRAPHDIVIDER), 80, 20, ST7735_WHITE); tft.drawFastHLine(5 + (preWeldTime / GRAPHDIVIDER), 100, (COOLDOWNTIME / GRAPHDIVIDER) + 1, ST7735_WHITE); tft.drawFastVLine(5 + (preWeldTime / GRAPHDIVIDER) + (COOLDOWNTIME / GRAPHDIVIDER), 80, 20, ST7735_WHITE); tft.drawFastHLine(5 + (preWeldTime / GRAPHDIVIDER) + (COOLDOWNTIME / GRAPHDIVIDER), 80, (weldTime / GRAPHDIVIDER), ST7735_WHITE); tft.drawFastVLine(5 + (preWeldTime / GRAPHDIVIDER) + (COOLDOWNTIME / GRAPHDIVIDER) + (weldTime / GRAPHDIVIDER), 80, 20, ST7735_WHITE); tft.drawFastHLine(5 + (preWeldTime / GRAPHDIVIDER) + (COOLDOWNTIME / GRAPHDIVIDER) + (weldTime / GRAPHDIVIDER), 100, COOLDOWNTIME, ST7735_WHITE); lastPreWeldTime = preWeldTime; lastWeldTime = weldTime; } // read the state of the switch into a local variable: int reading = digitalRead(buttonPin); // check to see if you just pressed the button // (i.e. the input went from LOW to HIGH), and you've waited // long enough since the last press to ignore any noise: // If the switch changed, due to noise or pressing: if (reading != lastButtonState) { // reset the debouncing timer lastDebounceTime = millis(); } if ((millis() - lastDebounceTime) > debounceDelay) { // whatever the reading is at, it's been there for longer // than the debounce delay, so take it as the actual current state: // if the button state has changed: if (reading != buttonState) { buttonState = reading; // only toggle the LED if the new button state is HIGH if (buttonState == HIGH) { ledState = !ledState; //************************************************************************************************** Serial.print("Pre weld time set to: "); Serial.print(preWeldTime); Serial.print(" ms\n\r"); Serial.print("Weld time set to: "); Serial.print(weldTime); Serial.print(" ms\n\r"); String strBuffer = String("!WELDING!"); tftPrintText(strBuffer, 10, 125, 2, ST7735_RED); // Do pre heating sequence based on predefined fraction of the total welding time digitalWrite(relayPin, LOW); // Relay is active low digitalWrite(ledPin, HIGH); // LED is active high delay(preWeldTime); digitalWrite(relayPin, HIGH); digitalWrite(ledPin, LOW); delay(COOLDOWNTIME); // Do welding digitalWrite(relayPin, LOW); digitalWrite(ledPin, HIGH); delay(weldTime); // Reset all ports digitalWrite(relayPin, HIGH); digitalWrite(ledPin, LOW); tftPrintText(strBuffer, 10, 125, 2, ST7735_BLACK); // Restart loop //**************************************************************************************************/ } } } // save the reading. Next time through the loop, // it'll be the lastButtonState: lastButtonState = reading; } void displayInitScreen(void) { tft.initR(INITR_BLACKTAB); // initialize a ST7735S chip, black tab tft.setRotation(0); tft.fillScreen(ST7735_BLACK); char display_buffer [20]; memset(display_buffer, 0, 20); sprintf(display_buffer, "Spot Welder v0.1"); tft.setTextColor(ST7735_WHITE); tft.setTextSize(1); tft.setCursor(0, 0); tft.print(display_buffer); memset(display_buffer, 0, 20); sprintf(display_buffer, " MicroForge - 2018"); tft.setTextColor(ST7735_WHITE); tft.setTextSize(1); tft.setCursor(0, 10); tft.print(display_buffer); //delay(1000); //tft.fillScreen(ST7735_BLACK); String strBuffer = String("Spot weld timing:"); tftPrintText(strBuffer, 0, 35, 1, ST7735_YELLOW); } void tftPrintText(String textBuffer, int x, int y, int textSize, int color) { if (textSize == 0) textSize = 1; tft.setTextColor(color); tft.setTextSize(textSize); tft.setCursor(x, y); tft.print(textBuffer.c_str()); }Here is the resulting visualization for both peeks as well as the exact times of both weld actions.
Building the thing...
01/06/2018 at 06:39 • 0 commentsIn order to weld metal to metal with a spot welder two things are important:
- a certain pressure onto the material with the electrodes to establish proper conductivity
- the time it takes to weld the material
The first bit can be achieved by hinging both arms individually and make both of them spring loaded. I didn't have any springs to I used a ring of ninjaflex for 3D printers instead. Works great! (thus far).
The time to weld the material is another story that I will cover in the software log.
I wanted to create an enclosure that is easy to move around, has exposed arms, a display, a fuse behind a service bay, the potentiometers, as well as my favorite 86ct wall switch from Home Depot. It also needed to provide enough strength to house the heavy transformer as well as the double hinged arms that really shouldn't move at all - except vertically.
It's essentially a box. It has everything described above and it made from sturdy 5mm plywood from Home Depot. The front is only 3mm plywood because I needed to be able to mount the potentiometers as well as the display properly. The rest is decoration.
On the inside, there is the fuse block, the $1 wall charger from Dollar Tree (I really went all in here!) as well as the $2 Arduino relay. I mounted everything to the front plate that is either 5V or needs to be swapped out ones in a while.
The hinge mechanism is equally simple. I just needed to constrain the two arms in all axis except one. This is possible with stiff side plates and a center plate to keep them apart which is why there are three plates glued to the top cover instead of just the outer two.
In the end it pretty much looked exactly the same in real life:
I lasered everything out on my modified K40 China laser that I couldn't live without and started putting the enclosure together. Unfortunately, I ran out of 12x3mm screws so I had to revert back to gluing instead of screwing. Not exactly what I wanted but it works as well. It made the process only marginally more complicated and it's still very serviceable and cheaper.
I put a switch inside the hinge mechanism to auto-fire the welder as soon as I pressed the electrodes against the material to weld with sufficient force.
The resulting enclosure looks cool on my desk and really works well. I can put the welder where ever I want. The wall switch really works well on the front as well.
The display is easily readable from the operators point of view. The contrast is actually very nice when viewed from the front.
Shortly after everything was put together I started to make some test welds. Of course! I couldn't wait to test my software and I was very eager to learn two things:
- How will the sudden power surge affect the Arduino with its $1 power source?
- Will the Arduino relay straight out of China even survive one operation?
To my big surprise the answer to both these questions was very positive! Everything works! I even started dialing in the durations for both pre-weld and weld since my 0.2x8mm Nickel strips needed a lot less time to weld than my 0.75mm steel strips. Not exactly surprising.
What I really liked about this was the test to rip the welded strips apart.
I couldn't.
I used two pliers and all the force I was able to exhibit and only one welding spot popped off and left a hole! DANG!
In the end I tested my new tool with $1 batteries (8 for $1 - guess from where). I just wanted to weld something. The batteries are utter crap and I would never buy them again for anything serious but for a welding exercise they seemed perfect.
They weren't.
Apparently, the negative pole of the battery is just a cap and separates itself from the battery when the heat shrink melts. Its literally not connected to the battery except by touching the surface. However, this is the nice side of the pack and I'm extremely happy with the results! Maybe even a bit too long weld time but I don't care at this point.
This will become more important when welding the actual 18650 battery packs.
The hard way...
01/06/2018 at 06:33 • 0 commentsTrigger happy I was when I first tested the transformer for spot welding. I literally plugged it into the mains power with a switch and turned it on and off in rapid succession. This works surprisingly well and I would test like this again if I have no other choice.
However, I have a choice since I love building embedded systems.
I have some Arduino Nano flying around because it's by far my favorite form factor for a micro controller project and bloody cheap. I quickly put together a bead board to test my control scheme with the actual target hardware: A $2 Arduino relay. Not exactly the most durable solution to switch 15A under load. Anyways. We will see how long it will last and if swapping it out is more of a hassle than designing a direct replacement TRIAC circuit.
The dry run worked and I started designing an actual PCB.
I wanted to mount the display directly to the board to avoid wires as much as possible. It was supposed to go onto the back of the PCB while the Arduino sits on the front side. Other than that, there is not much to it. Two potentiometers, one switch that needs to be pulled to ground as well as the relay circuit. That's it.
Certainly not a pretty board but it took me less than 2h to design it and 45 minutes to mill it on my PCB mill. Talk about rapid prototyping! I just wanted to get this over with because I was running out of vacation days.
I put the board together and tested the design and I extremely happy when it powered up and worked right away.
I love my PCB mill and I'm very happy with the results even though I need to make my restrings for vias and pads significantly larger from now on. It was also a mistake to drill the holes smaller than 0.8mm. Unfortunately, Eagle is still a bit dumb and gives very inconsistent results when making restrings larger in the design rules and then using copper filling around the traces and pads. Apparently, you can make restrings larger but the clearance around the pads won't automatically grow. As a result you will manually adjust the spacing around the traces and vias/pads but that will cause a lot longer milling times and also doesn't work with ground (GND) vias/pads for some awkward reason.
Starting the log...
01/04/2018 at 04:29 • 0 comments"I think I want to build an eSkate.."
"Why?"
"Because I think the commercial versions are too expensive and don't pack enough range for actually being usable for commuting"
"... great! I guess ..."
If you had a conversation like that if your life, you're very likely to have one of these spot welders somewhere in your workshop. Spot welders. Why a spot welder?
It's simple:
With a spot welder your can weld metal to metal without actually adding material. You just melt both materials and mix the viscose metals into one object. It's actually that easy.
Spot welding comes in two variants (as far as I know):
- Welding from opposing sides (like used in the automotive industry)
- Welding side by side (like used for almost all battery packs on the planet)
When I started researching material for electric skate boards there were two types of people. One is using lipos straight from a hobby store and one is going the extra mile to use 18650 or bigger batteries and make their own packs. Both works well. In fact, it seems easier to identify shitty lipos from HobbyKing than shitty 18650s even from sources like Amazon or ebay because people know them already and there are not as many counterfeits.
However, people using the 18650s are convinced it's the better battery technology. They are widely used in laptops and Tesla's and many other electric vehicles out there. So why not use genuine 18650 cells and make a great high power pack? Because you need decent tools to make the actual pack. Like a spot welder, a long strip of Nickel as well as a decent battery management system to keep all individual cells balanced. Always.
So, ok. What do I need for making a spot welder:
- A high power transformer that can be converted to a spot welder
- A switch able to switch 15A 120V reliably
- A fuse would be great
- Something to time the actual welding. Manually works as well but I'm an embedded systems engineer
- An enclosure so that the spot welder can be on my desk as well as being transported when I move
- VERY thick wire that allows enough current without much loss and without getting hot in the process
- Some type of electrodes that transfer the current into the material to be welded without loosing integrity due to overheating or even get welded themselves in the process
All of the above is relatively easy to obtain, starting with the transformer.
Most people salvage their transformers from old microwaves. People also say that it should have more than 1000 Watts. I found the latter to be untrue. The microwave I stripped was only 750 Watts and the current seemed to have been limited by the use of magnetic shunts inside of the transformer that I could remove. It turns out, my transformer runs at 14.5 Amps during welding and at 4.5 Amps when free flying after removing the magnetic shunts.
P = U x I gives us 120V x 14.5 A = 1.740 Watts! Geeeeezzz! Far more than enough!
My configuration has only 2 windings on the secondary coil and an unknown number of windings on the primary coil. However, what I do know is that 120 VAC get transformed down to 2VAC! That's a factor of 60!
Considering that the primary coil draws 14.5 Amps during welding, this should translate (x60) to 870 Amps on the secondary coil during welding.
If you look at the wire you are supposed to use for this type of current you will end up with something that is essentially unusable and unobtainable. Not surprisingly, most people just use some "thick wire" to build their welders and of course will never achieve these currents during their spot weldings. The internal resistance of the wire itself is just too high and the voltage will break down.
However, I was able to acquire "1 AWG" which is rated for a max current rating of somethingsomething 200 Amps continuous. That seems ridiculously low considering the thickness of the material and having worked with RC cars before where something like a Mamba Monster Motor/ESC has a burst current of ~1000 Amps.
From my brief tests I can say the following: The wire does not get hot and I can weld 0.75mm steel plates on top of each other using simple copper electrodes and side by side welding.
The ratings mentioned in the standards are designed for continuous current. Spot welding utilizes very short bursts of current going through the material to weld it. A voltage drop is not important. Having the wire increasing the temperature by 0.1 deg C per weld is neglectable even when welding 100 batteries together. That's likely why most people use thick speaker wire or jumper cables to build their welders.
My first test looks like this:
Timo Birnschein
