a little problem
01/08/2018 at 22:00 • 0 commentsThe order of the instructions is a little off. Wiring the battery should be directly below preparing the tabs. The editor isn't letting me make this change, so I'll have to re-generate the instructions later.
instructions complete
01/08/2018 at 21:53 • 0 commentsThere, I've finished. I promise I'll make the code available for the Pong game once I write it!
mostly done
01/08/2018 at 20:13 • 0 commentsI've mostly finished the instructions. I still need to add pictures of the charging jack and flesh out the instructions for it a bit.
initial testing
01/05/2018 at 19:30 • 0 commentsParts received, project assembled and tested: it works!
Next I need to finish the writeup. Then on to writing the kernel module and Pong game.
