Hackaday.io Hackaday.io
Sign up Log in
Web-Controlled Music Player
This Web-Controlled Music Player showcases the capabilities of the gen4-IoD to serve as a web server.
4d-makers4D Makers
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1 comments
131 followers
  • Description
  • Details
  • Files 0
  • Components 5
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 1
View Gallery
124
1
131
1
Team (1)
  • 4d-makers4D Makers
Join this project's team
  • Web-Controlled Music Player
completed project
iot INTERNET OF THINGS gen4 iod display 4d systems MUSIC web
This project was created on 01/06/2018 and last updated 9 years ago.
Description
The project starts working when the gen4-IoD sets itself up as an Access Point, it will then generate an HTML web interface to control the SOMO-II Embedded Audio Module whenever a client/device connects to the IP address of the gen4-IoD web server. Inside the HTML web interface are simple buttons that provides trigger paths for the web server to catch. After catching these trigger paths, the gen4-IoD will provide the serial byte command trigger to the SOMO-II via the GPIO16.
Details
Components
  • 1 × gen4-IoD-32T With gen4-IoD Programmer and a 10 Way FFC Cable
  • 1 × SOMO-II An Audio Module by 4D Systems
  • 1 × Speaker 3 Ohms 4 Watts preferrable
  • 2 × uSD Card
  • 1 × Jumper Wires
Log In/Sign up to comment
Sign up with Github
OR
fabian wrote 07/21/2018 at 07:54 • point
not usefull, i need normal turnon-volume potenciometer
pilot, screen
if i have web i have a player too
A Web-enabled puppet that turns on your TV when Simpsons is on.
Project Owner Contributor
Smart Homer Web-enabled TV remote
tambergtamberg
The device that allows to turn on/off two pairs of the outlet sockets via Web browser through Wi-Fi. Based on ESP8266 and Arduino Mini.
IoT Power Strip
dev-labdev-lab
A useless box with a web interface served from a free hotspot
ESP8266 Useless Throwie
mike-causerMike Causer
Evil-M5Project is an innovative tool developed for ethical testing and exploration of WiFi networks.
Evil-M5project
7h30th3r0n37h30th3r0n3
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Web-Controlled Music Player", please tell us the reason.
Send message
Remove Member
