A case and POE for the OrangePI
Technically, the OrangePI Zero supports a type of Power of Ethernet, but this makes it compliant.
...and uses a cheat - you can buy POE splitters off Aliexpress - this hack removes the Ethernet port off the OrangePI, and permanently attaches the splitter. I also 3D printed a case for it, which is the interesting part, as I experiment with post production.
I use an OrangePi as a server for my Flic bluetooth buttons. I use POE to power it, so I don't need to bother with plug packs, however, it all looks a little untidy (why do Pi clone manufacturers always put the power plug on the front!?).
I've also been meaning to experiment with sanding and spray painting 3D prints, so I thought I'd kill two birds with one stone.
Top.stl
Top part off the case. Has clips to hold the board - they don't work - cut them off, and drill two 2.5mm holes in the rear two stalks, and screw the OrangePi in.
Standard Tesselated Geometry - 878.01 kB - 01/07/2018 at 10:14
Download
Base.stl
Base section of case. Attaches to the Top with 4 x M3 screws
Standard Tesselated Geometry - 176.64 kB - 01/07/2018 at 10:14
Download
  • Painting
    Myles Eftos01/07/2018 at 10:58 0 comments
    FDM 3D printing is quite streaky, and looks... well, like it was 3D printed. I print in PLA, so acetate vapor is out off the question, making good, old fashioned sanding and painting the easiest way to get it looking it good.
    The first time I tried this I sanded the thing completely smooth, and it took ages. I found other people have had success using automotive primer/filler which fills smaller scratches.
    I tried this, but the gaps were too big. I went aggressive, and started with 120grit wet-and-dry sand paper. I added another two coats of primer/filler. Next, I went to town with 400 grit, then 800 grit.
    I wanted to see if I could paint a logo in the top, so I did an undercoat of satin silver, placed a sticker over it and then painted a top coat of satin grey.
    It looked terrible.
    1. The sticker lifted, so the edges off the logo were blurry.
    2. Satin shows up ALL the gaps, so even after all the sanding, the lines were still visible
    3. I over painted, so there was drips, and it looked thick and gross
    4. The colour wasn't... great.
    I re-sanded with 400-grit to get rid of the paint, and polished again with 800-grit. This time I omitted the extra coat of primer/filler, and just applied two LIGHT coats of flat (matt) black paint. This time the result was great!
    Matt paint actually fills gaps a little bit, so the result is much better. There are still some visible lines (in the right light), so clearly I need to sand more. Also - I missed some bits on the bottom section. Clearly I still need some practice.
    I wouldn't mind trying the satin finish again, with out being so heavy handed on the paint.
View project log
  • 1
    Desolder the Ethernet socket from the OrangePi.
  • 2
    Desolder the ethernet and power cable from the POE splitter
    This time: Solder sucker.
  • 3
    Connect the two boards
    I used ethernet cable, maintaining the twists. I also soldered two pin headers into the support holes either side of the ethernet sockets, to give some physical support.
View all 7 instructions
