1Desolder the Ethernet socket from the OrangePi.
I used a desoldering needle.
2Desolder the ethernet and power cable from the POE splitter
This time: Solder sucker.
3Connect the two boards
I used ethernet cable, maintaining the twists. I also soldered two pin headers into the support holes either side of the ethernet sockets, to give some physical support.
43D print case
You need to cut off the board support clips at the top of the pylons - they don't work. Drill two 2.5mm holes in the two rear pylons
5Insert brass inserts into the corner holes.
I used a soldering iron.
6Insert the board
Screw down the board using the back two holes with M3 screws.
7Close the case.
