1Step 1
Design the required parts and cut them using a laser printer or if you're more crafty using a saw.
2Step 2
Screw the servo motors to the relative parts as you can see in the picture below and attach all parts.
3Step 3
The servos were all connected to the ServoDroid board.
An extension was used for the gripper servo wire
4Step 4
Finally just plug the ServoDroid board into your phone's audio jack using the cable and you can start controlling robot using the servo controller app.
melvin zammit
