This board is heavily inspired and based off of the LittleWire and DigiSpark projects, with some little features of my own added to it.
It operates using either 5V or 3.6V, selected by jumpers, also has silkscreen reference for digispark features, as well as the ISP features of LittleWire. Will run the micronucleus v1.11 firmware.
So, being my first PCB design to be manufactured, this board has a couple of mistakes. The first, is that the power and I/O header holes are slightly too small because I used the incorrect KiCAD footprint. This was solved by forcibly jamming the header pins in the holes, which is definitely not a very good fix, but it works. The other major mistake was that the area for a USB MALE A plug actually had the pin0out of a USB female plug in the footprint, so if I want to use a USB MALE A plug, I will have to solder it on the other side of the board. Luckily, I included both a Mini-USB B port option as well as the USB MALE A plug, so I did that and got some practice with SMD connections.
Well, here is a picture of the board successfully running a classic toggling led program:
The littlewire firmware works on it as well, and I have been able to upload programs to my AVR_board_m8515 with it.
