1Step 1
Get hold of PCB board.
For example with:
http://dirtypcbs.com/view.php?share=1062&accesskey=fa772e16543f8e868555ccbc2bad097e
2Step 2
Solder in Caps, Resistor and Pushbutton.
3Step 3
Optional: solder LM117T-3.3V voltage regulator
4Step 4
Solder in Connectors i.e. three pins for power suppls (5V, 3.3V, GND) and TEST and RST
5Step 5
Solder in Microcontroller (the mark is towards power source)* Program with Launchpad (unplug all jumpers, connect ground and 3.3V or ground and 5V (when using a voltage regulator), connect TEST and RST, optional connect TX RX for UART-connection)
6Step 6
Program and have fun.
7Step 7
Optional for DS18B30 connect voltage supply and GND to GND of MSP430 (parasitic supply) and Data to the correspondent data pin of code (in my case BIT7).
lageos
