Roll Animation Video
01/22/2015 at 11:46 • 0 commentsRoll animation vid uploaded, next step, record an explanatory vid.
Roll Animation
01/21/2015 at 12:02 • 0 commentsa .gif of the roll animation... the colours don't come out very well in the video, but you can see them reflected on the wall behind :-)
will add youtube stuff soon
Mostly complete
01/21/2015 at 11:27 • 0 commentsok, so now pretty much all of it is done...
from left to right, we have:the LED array
the rainbowduino V3 board
a lipo battery (the piezo will go here too)
a board which supports the switch
a board that holds the switch in place
some height adjustment bits with some springy sponge (switch spring is not strong enough on its own)
this fits into the box which contains the lipo charge/boost board, mode switch and power switch (some burn marks from a heat gun)
Dual Die
10/22/2014 at 14:56 • 0 commentsAfter some experimenting with the rainbowduino and playing with custom fonts, the result is the following:
now to add the features... :-)
David Hopkins
