1Step 1
Use P3_0 and P3_1 to communicate with the ESP8266 RX/TX via a 5v<>3.3v shifter., add UART component and config to 11500kbps, 1024 rx buffer, 128 tx buffer (or less) default everything else.
Add a X to 3.3V VREG and power the ESP8266 and level shifter.
Make CH_PD high.
I'll publish all the code and doc's after i've made sure it's right. so far its been running for about 14 hours straight.
Uploaded schematic on github, my first github commit. i still like svn ;)
charliex
