« Back to project details
Reading out original Firmware
12/04/2016 at 10:00 • 0 commentsToday I got to a point when I have hooked this to my Nucleo board.
The J6 pinout from years ago seems to be correct. I have wired the SWD pins only and started openOCD installed along with the Ac6 STM32 System Workbench recent version.
/opt/Ac6/SystemWorkbench/plugins/fr.ac6.mcu.externaltools.openocd.linux64_1.12.0.201611241417/tools/openocd/bin/openocd -f getyoo_clickey.cfg -s /home/mm/workspace/getyoo_clickey -s /opt/Ac6/SystemWorkbench/plugins/fr.ac6.mcu.debug_1.11.1.201611241417/resources/openocd/script
For the getyoo.cfg see the attached files.
After openOCD started:
Open On-Chip Debugger 0.10.0-dev-00273-g394abef (2016-11-24-15:12) Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD adapter speed: 1000 kHz adapter_nsrst_delay: 100 srst_only separate srst_nogate srst_open_drain connect_assert_srst none separate 3333 Info : Unable to match requested speed 1000 kHz, using 950 kHz Info : Unable to match requested speed 1000 kHz, using 950 kHz Info : clock speed 950 kHz Info : STLINK v2 JTAG v19 API v2 M v2 VID 0x0483 PID 0x374B Info : using stlink api v2 Info : Target voltage: 3.259064 Error: BUG: can't assert SRST Info : STM32F102CBTx.cpu: hardware has 6 breakpoints, 4 watchpoints
Telnet to the port 4444:
telnet localhost 4444
Then read the flash:
> flash banks #0 : STM32F102CBTx.flash (stm32f1x) at 0x08000000, size 0x00000000, buswidth 0, chipwidth 0 > flash read_bank 0 getyoo.bin 0 0x1FFFF device id = 0x20036410 flash size = 64kbytes wrote 131071 bytes to file getyoo.bin from flash bank 0 at offset 0x00000000 in 2.561862s (49.963 KiB/s)
