Stickvise_CupHolder_Jaw.stl
Make your Stickvise into a big spring loaded cupholder. This is one jaw, so two will need to be printed.
Standard Tesselated Geometry -
409.46 kB -
08/11/2017 at 18:34
Download
Stickvise_InterlockingV.STL
Interlocking Jaws - My favorite jaws, these hold a PCB as well as any size cylindrical part horizontally (from a small wire to a cable to a 1" diameter motor)
114.93 kB -
02/28/2016 at 12:24
Download
Stickvise_VJaw.STL
Jaws with vertical v-grooves for holding cylindrical parts upright
264.14 kB -
02/28/2016 at 12:24
Download
Stickvise_Grooved_Jaw.STL
wire grooves everywhere, this jaws is almost obsolete compared to the interlocking jaws, but it uses less printer material
177.82 kB -
03/04/2016 at 01:13
Download
Stickvise_TallJaw.STL
Raise the PCB up to acommodate tall components
30.94 kB -
02/28/2016 at 12:24
Download
Stickvise_MedJaw.STL
Raise the PCB up to acommodate medium components
30.94 kB -
02/28/2016 at 12:24
Download
Stickvise_LowProfileJaw.STL
These are the same as the standard Stickvise jaws
30.94 kB -
02/28/2016 at 12:24
Download
