I got a New Camera!!!
04/09/2020 at 21:53 • 0 commentsI got an Insta360 video camera for the live stream highlights, and WOW! I have all shots, just edit how I please and have a much higher quality video! It really helps never missing anything, which I did a lot of when I was just using my phone.
And here are the last of the phone only videos!
New Website Database Code for Twitch Buttons
03/31/2020 at 12:58 • 0 commentsWix stopped allowing me to add random users to my email crm contact list. A bug, but one that seems to persist even if "fixed" on there end. So it was back to the drawing board.
Wix, does allow a database to be maintained and for the user to build an api to access different elements of one's site. So I set up my buttons to input into the database, based on mouse clicking see code:import wixData from 'wix-data'; $w.onReady(function () { //TODO: write your page related code here... }); export function B4_rainbow(event, $w) { //look at database and see the number of results in it. wixData.query('interactions').find().then(result=>{ let record = result.items[0]; //item with values // increment this by 1 record.b_4++; // the rainbow effect is attached to b_4 value in my database console.log(record.b_4); //let me know i've done something //save the new data back into the interactions database wixData.update('interactions', record).then((results) => { let item = results; //see item console.log(results); } ) .catch( (err) => { let errorMsg = err; } ); }); }Now to build the backend of my site, so I can access the values from an HTTP- request
import {ok, notFound, created, serverError} from 'wix-http-functions'; import wixData from 'wix-data'; // function to read my database, and return a json string of all the elements of my database in it. export function get_readInteractions(request) { let options = { "headers": { "Content-Type": "application/json" } }; return wixData.query("interactions") .find() .then( (results) => { if(results.items.length > 0) { options.body = { "results" : results.items } return ok(options); } }) }But I want a way to store my high fives I get out in person, back into my database. Luckily there is a way to do that as well! (please do not abuse this function, it only makes it seem that I've high fived people, anyway)
export function put_highfives(request) { wixData.query('interactions').find().then(result=>{ let record = result.items[0]; //item with values record.highfives++; // increment this by 1 console.log(record.highfives); wixData.update('interactions', record).then((results) => { let item = results; //see item console.log(results); } ) .catch( (err) => { let errorMsg = err; } ); });I tried to do a put request at first but kept running into problems. I also don't necessarily know what my current high five count accurately. So I decided the best thing was to just alert my website that a high five has occurred and let it handle querying and incrementing the high five value. Later on I did find a way to put the high five information back into my glove and tvhead, through twitch, but another topic for another day.
With the website now modified, time to re-write the portion of my python script that read my website. Now more email crawling.
The http - request :
https://www.natedamen.com/_functions/readInteractions
def getData(): try: rk = requests.get('https://www.natedamen.com/_functions/readInteractions') except Exception as err: print(traceback.format_exc()) else: datak=rk.json() return datak #gets all of the unread messages from the inbox def dataCrawler(): t=0 mCheck = True datar=getData() oldR=datar while True: ot=time.time() diff = ot - t #I was getting a lot of errors and crashes, so I want to know what is failing. #This section of code does that, and closes out this script. try: datar=getData() except Exception as e: err=e.args[0] print('Data crawler down: '+ str(err)) sys.exit(0) # if Data is different from older data, trigger a tvhead command to twitch. if datar['results'][0]['b_1'] > oldR['results'][0]['b_1']: chat(s,"<3") time.sleep(1 / RATE) if datar['results'][0]['b_2'] > oldR['results'][0]['b_2']: chat(s,"!sparkles") time.sleep(1 / RATE) if datar['results'][0]['b_3'] > oldR['results'][0]['b_3']: if mCheck == True: chat(s,"!mirrorDown") mCheck = False else: chat(s,"!mirrorRight") mCheck = True time.sleep(1 / RATE) if datar['results'][0]['b_4'] > oldR['results'][0]['b_4']: chat(s,"!rainbowHeart") time.sleep(1 / RATE) if datar['results'][0]['b_5'] > oldR['results'][0]['b_5']: chat(s,"!Mahearta") time.sleep(1 / RATE) if datar['results'][0]['b_6'] > oldR['results'][0]['b_6']: chat(s,"!heartCycle") time.sleep(1 / RATE) if datar['results'][0]['b_7'] > oldR['results'][0]['b_7']: chat(s,"!sGlitch") time.sleep(1 /RATE) if datar['results'][0]['b_8'] > oldR['results'][0]['b_8']: chat(s,"!noiseScreen") time.sleep(1 / RATE) if datar['results'][0]['b_9'] > oldR['results'][0]['b_9']: chat(s,"!jellyHeart") time.sleep(1 / RATE) if datar['results'][0]['b_10'] > oldR['results'][0]['b_10']: chat(s,"!reset") time.sleep(1 / RATE) chat(s,"!mirrorOff") time.sleep(1 / RATE) chat(s,"<3") time.sleep(1 / RATE) if datar['results'][0]['b_11'] > oldR['results'][0]['b_11']: chat(s,"Selecting Atltvheads!") time.sleep(1 / RATE) if datar['results'][0]['dim'] > oldR['results'][0]['dim']: chat(s,"!dimmer") time.sleep(1 / RATE) if datar['results'][0]['bright'] > oldR['results'][0]['bright']: chat(s,"!brighter") time.sleep(1 / RATE) oldR=datarI want this python code to run non-stop. So I ended up using the multiprocessing library allowing for twitch communication to be run in it's own process, and this data gathering done in another process. but when one process goes down, it doesn't work. They both share variables, and functions. Needless to say, there are a lot of ins and outs and interested parties.
So after struggling to have debug both subscripts to eliminate all of the expectations and errors, for months, I conceded slightly. I decided the best thing is just to see if the processes are running, if not, restart them. Put a bandaid over the problem. If any exceptions that I didn't fix or didn't account for come up, just close the process and restart it. If the twitch process went down, I'd also need to restart the connection,
if __name__ == '__main__' : p = multiprocessing.Process(target=pingPong) m = multiprocessing.Process(target=dataCrawler) m.start() print('Started Email Scanning') p.start() print('ping pong started') while True: if not p.is_alive(): print('P is :') print(p.is_alive()) while not CONNECTED: try: s.connect((cfg.HOST,cfg.PORT)) print('reconnected to twitch') except socket.error: print(traceback.format_exc()) else: s.send("PASS {}\r\n".format(cfg.PASS).encode("utf-8")) s.send("NICK {}\r\n".format(cfg.NICK).encode("utf-8")) s.send("JOIN {}\r\n".format(cfg.CHAN).encode("utf-8")) CONNECTED = True finally: #print('socket error') time.sleep(2) print('P is :') print(p.is_alive()) p.terminate() time.sleep(1) p = multiprocessing.Process(target=pingPong) p.start() print('ping pong restart') elif not m.is_alive(): print('M is :') print(m.is_alive()) m.terminate() time.sleep(1) m = multiprocessing.Process(target=dataCrawler) m.start() print('data scan restart') else: time.sleep(.25) time.sleep(1)Now my website and twitch code run 24-7! You can check it out at https://www.atltvhead.com Click some buttons and see them appear in the chat box. Also if you'd like to see how many of each button is pressed, you can access my database with this http request
YAY FOR FIXED WEBSITE BUTTONS!
57th Atltvhead Stream highlight!
03/04/2020 at 13:41 • 0 comments -
56 Hype!
02/27/2020 at 04:28 • 0 commentsEpisode 56 Is out!
Video Upload!
01/21/2020 at 12:50 • 0 commentsAfter many a month of forgetting to upload videos to youtube, I did it. Here is a big list of past few weeks of the atltvhead project!
BOOM!
Alright. I have also added some features to tvhead's high five glove! It now records high fives to my online database. I just have the base function working and still need to add in some extra code to switch rows for different dates, but its still collecting the total high fives since implemented!
I'll do another log for that explanation.
Video 51, Video format Changes
11/19/2019 at 21:24 • 0 commentsHey everyone. This project is continuing pretty well. I just rebuilt the front screen, because the old one got pretty gross. I'll include some build photos of that in a sec.
Editing weekly videos, is just a little burdensome. So I am waiting until I live stream 3 times, then I'll compile and edit the footage.
Remember anyone can control the tv screen during the live streams. Follow me on Insta and on Twitch to see when I am streaming!
<3
Nate
Week 50!
10/22/2019 at 19:02 • 0 commentsIt was a fun one! Sorry I'll update the videos inbetween soon. Everything is posted to Instaglam at first, then elsewhere. Gotta glam ;)
More Videos!~
08/15/2019 at 03:05 • 0 comments -
More Beltline Logs!
06/13/2019 at 02:19 • 0 comments -
More Weekly Highlights
05/17/2019 at 01:44 • 0 commentsI am working to put in tic-tac-toe as a play mode on tvhead! lets see it happen in the next few weeks. In the meantime here are some more highlights!
atltvhead
