1Step 1
Get all the design files from the main repo: https://github.com/mastrogippo/1337-3310-tool
2Step 2
Build the hardware! (srsly?) :)
3Step 3
Download the firmware, binaries and tools from here: NokiaPack
4Step 4
If you're lazy go to step 10, if not read on to generate the Font and Bitmap binaries yourself
5Step 5
Use the PPM editor in the NokiaFirmware folder with the .fls file to export the .pef file with the fonts and a folder with all the bitmaps in the original firmware
6Step 6
Get the Bitmap converter: https://github.com/mastrogippo/BitmapToBinary
7Step 7
Place the bitmaps in the "bmp" folder with the BitmapToBinary exe, run the program, select the bitmaps to include and click "Gen"
8Step 8
Get the PEF Fonts tool: https://github.com/mastrogippo/PEF-Fonts
9Step 9
Place the font PEF file in the same folder as the PEF Fonts executable, run it to generate the font binaries, save them and the listed offsets
10Step 10
Get the EEPROM upload tool: https://github.com/mastrogippo/Arduino-EEPROM-Upload
Mastro Gippo
