TrinketWidget
Simple Field Automation Widget
Throw it in your bag, write simple automation scripts in any language you want, control via bluetooth
  • Small rugged little device.
  • Simple ASCII command line interface over bluetooth serial port.
  • GPIO
  • Analog Pins
  • Battery Powered
  • Programmable RGB Status LED
I plan to wrap all of this functionality in a library, and make it easy to extend this device with custom functionality.
It's kinda like bus-pirates wireless little brother.
Here is the code: https://github.com/pborges/TrinketWidget
Its a work in progress...
  • 1 × Adafruit Pro Trinket - 3V 12MHz
  • 1 × NeoPixel Mini PCB
  • 1 × HC-05 Serial Bluetooth on breakout board
  • 1 × Adafruit Pro Trinket LiIon/LiPoly Backpack Add-On
  • 1 × Lithium Ion Polymer Battery - 3.7v 500mAh
View all 2 project logs
Paulo Borges wrote 12/09/2014 at 15:36 point
If I get the time I would love to at-least implement i2c, and spi... right now I'm only targeting some GPIO and a couple high-current outputs.
Stefan Lochbrunner wrote 12/08/2014 at 17:48 point
Sounds cool! I hope you get most of the Bus Pirate features implemented. I could especially see myself use a wireless AVR programmer.
I was wondering if you are aware of https://github.com/tobyjaffey/bus-ninja and https://github.com/chatelao/MiniPirate . They are very similar to this project and might be helpful.
