Demo Videos
12/29/2014 at 04:29 • 0 commentsHere is a demo video of monitoring the power going from as USB cable to my phone:
Here is a demo video of the power monitor showing the voltage/current within its own charging cable (whilst charging itself!):
Transfer to Protoboard
12/23/2014 at 04:54 • 0 commentsAfter getting the Trinket, LCD, and INA219 to work on a bread board I drew up everything on Fritzing so I had a reference should anything go wrong whilst transferring onto a permanent proto-board.
I intentionally soldered on female pins so that:
1. All components could be easily replaced should they fail.
2. Components could be upgraded such as the LCD from size 16x2 to 20x4.
3. I could remove and use the components for other concurrent projects to save money.
Transfer to Trinket and Reading out to LCD
12/23/2014 at 04:47 • 0 comments29 NOV 14
Modifying the Arduino code and moving around some input pins to get the LCD pins and INA219 to fit nicely onto the Trinket.
Proof of Concept
12/22/2014 at 00:08 • 0 comments15 NOV 14
I got the INA219 to give a Serial Readout of using an Arduino UNO thanks to the Adafruit Tutorial.
I also got the UNO to readout the current and voltage onto a 16x2 LCD.
John117
