Software started
01/26/2015 at 21:28 • 0 commentsWriting some software to graph the curve of NTC resistive dividers.
Hardware Assembly
12/15/2014 at 09:14 • 2 commentsI will be using the 'junk box' for a lot of the bits used.
I found a project box about the right size.
I didn't want to have the Toroidal's mounting bold sticking out the bottom of the box so I made a false bottom by cutting up a cheap bread board from a discount store.
Then mounted it into the box.
I mounted enough of the mains parts so that I could move on to the low voltage stage.
More to come.
Just a quick update (02/01/2015) I am waiting for Type 'K' thermocouple temperature meter so that I can map out the resistance graph for the PTC in the iron.
