I found the front case/keypad of an HP-21 in electronics recycling a while ago. I'm going to try to get it working again with Trinket guts.
I made a 3D CAD model of the rough dimensions of the case front in SketchUp, to make sure the components all fit well:
The hatched part is the boundary of the interior space; the brown boxes are exclusion zones for the screw receptacles that stick up. The gray and yellow thing is a battery; any of the reasonably capacious batteries from Adafruit and SparkFun will fit. The white thing is the SparkFun SX1509 breakout board I'm going to use to control the display (3 SparkFun bubble displays) and read the keypad.
hpmuseum.org has a forum
They might be able to help you with how to hook up to the existing display and keyboard (once they get over the initial shock of some one butchering a beloved HP calc!) Or they may be able to help you resurrect it instead. I used to follow the forum daily, some pretty bright and helpful people there.
20 according to this: https://learn.adafruit.com/introducing-pro-trinket/pinouts
I was thinking of using an SX1509, but I don't know if it could be driven fast enough for display multiplexing. I'll have to try it when I get around to working on this again.
Oh, I'm sorry, you mentioned it was only a shell with keypad, but the MoHPC members will probably want to hear from you anyway.
