Designing a new inner/outer backplate and cooling/charging circuit for the Samsung Note4 Phone
Since we're proposing cooling through the back of the PCB: https://books.google.co.jp/books?id=AUHqhqn7mRMC&pg=PA81&lpg=PA81&dq=heat+sink+touching+pcb&source=bl&ots=NDYtBV4sw8&sig=zlx7pEUYNfe9Y0Dmos4UB1VOs0I&hl=en&sa=X&ei=3-KcVKTRK-XVmgW49IKgBQ&redir_esc=y#v=onepage&q=heat%20sink%20touching%20pcb&f=false
Good teardown images: http://www.gizmochina.com/2014/10/07/samsung-galaxy-note-4-tear-down/
Possible fan: http://www.frozencpu.com/products/5572/fan5v-02/Evercool_30mm_X_7mm_5_Volt_Fan_-_EC3007M05CA.html?tl=g36c231s598#blank
Adafruit has female USB micro-B ports with a plastic shroud piece, and I think SparkFun has PCB-mount ones.
The heatsink could possibly be printed from brass http://www.shapeways.com/materials/brass?li=nav
We need a source for these that does not have such a large minimum order: http://www.alibaba.com/product-detail/SMT-DIP-1-6mm-and-2_1450678571.html
