code change, PIR and microphone
12/25/2014 at 11:06 • 0 commentsGot some basic stuff worked out for the PIR and microphone. Right now, he (not sure why I picked male gender, maybe the cool camo look?) makes two different beeps for the sensors, and reports a noteworthy sensor value over serial at 57600 baud.
//. Motor driver shield- 2012 Copyright (c) Seeed Technology Inc. // // Original Author: Jimbo.we // Contribution: LG // // This library is free software; you can redistribute it and/or // modify it under the terms of the GNU Lesser General Public // License as published by the Free Software Foundation; either // version 2.1 of the License, or (at your option) any later version. // // This library is distributed in the hope that it will be useful, // but WITHOUT ANY WARRANTY; without even the implied warranty of // MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU // Lesser General Public License for more details. // // You should have received a copy of the GNU Lesser General Public // License along with this library; if not, write to the Free Software // Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA // // // Basic motion based on A0 A4 sensor input by Aaron "Floz" Casper // for TankBot // // set up variables // name pins // int pinI1=8;//define I1 interface int pinI2=11;//define I2 interface int speedpinA=9;//enable motor A int pinI3=12;//define I3 interface int pinI4=13;//define I4 interface int speedpinB=10;//enable motor B int SpeakerPin = A5; int speed_A =0;//define the speed of motor_A int speed_B =0;//define the speed of motor_B const int photoCell_A = A4; // light sensor_A pin const int photoCell_B = A0; // light sensor_B pin const int PIR_signal_pin = A3; const int MIC_signal_pin = A2; int sensor_value_A = 0;// zero all our math int sensor_value_B = 0;// variables and sensors int sensor_value_PIR = 0; int sensor_value_MIC = 0; int output_value_A = 0; int output_value_B = 0; void setup() { // tell the arduino which pins are input and // which ones are output pinMode(MIC_signal_pin, INPUT); pinMode(PIR_signal_pin, INPUT); pinMode(photoCell_A, INPUT); pinMode(photoCell_B, INPUT); pinMode(pinI1,OUTPUT); pinMode(pinI2,OUTPUT); pinMode(speedpinA,OUTPUT); pinMode(pinI3,OUTPUT); pinMode(pinI4,OUTPUT); pinMode(speedpinB,OUTPUT); Serial.begin(57600); } void forward() { //This is really the only movement function used to begin with //it enables the motor to a speed determined by the photocell //this configuration should chase bright light. // analogWrite(speedpinA,speed_A);//input a simulation value to set the speed analogWrite(speedpinB,speed_B); digitalWrite(pinI4,LOW);//turn DC Motor B move clockwise digitalWrite(pinI3,HIGH); digitalWrite(pinI2,LOW);//turn DC Motor A move anticlockwise digitalWrite(pinI1,HIGH); } void stop() { // shuts the motors down by setting both speed-pins // to LOW digitalWrite(speedpinA,LOW);// Unenble the pin, to stop the motor. this should be done to avid damaging the motor. digitalWrite(speedpinB,LOW); delay(1000); } void loop() { // read sensor values sensor_value_A= analogRead(photoCell_A); sensor_value_B = analogRead(photoCell_B); sensor_value_PIR = analogRead(PIR_signal_pin); sensor_value_MIC = analogRead(MIC_signal_pin); // map sensor readings to 0-255 range sensor_value_MIC = map(sensor_value_MIC, 924, 1024, 0, 255); output_value_A = map(sensor_value_A, 0, 30, 0, 255); output_value_B = map(sensor_value_B, 0, 30, 0, 255); if (sensor_value_PIR <= 5){ tone(SpeakerPin, 200,50); Serial.println("motion detected!"); } if (sensor_value_MIC >= 75){ tone(SpeakerPin, 500,25); Serial.println("loud noise detected!"); } // normalize Mic input to 0-255 if (sensor_value_MIC >= 255){ sensor_value_MIC = 255; } if (sensor_value_MIC <= 0){ sensor_value_MIC = 0; } // don't pass values beyond what the motor controller // can handle for speed. if (output_value_A >= 255){ output_value_A = 255; } if (output_value_B >= 255){ output_value_B = 255; } // don't overwork the controllers trying to make tiny movements // chances are they won't turn on the motor enough to move, and // just get hot. if (output_value_A <= 128){ output_value_A = 0; } if (output_value_B <= 128){ output_value_B = 0; } // set the speed pin values for each motor controller speed_A= (output_value_A); speed_B= (output_value_B); //serial debugging output //Serial.print(analogRead(photoCell_A)); //Serial.print(" "); //Serial.print(output_value_A); //Serial.print(" "); //Serial.print(analogRead(photoCell_B)); //Serial.print(" "); //Serial.print(output_value_B); //Serial.print(speed_A); //Serial.print(sensor_value_PIR); //Serial.print(sensor_value_MIC); //Serial.println(" "); // move forward with speed_A and speed_B //UNCOMMENT THE FOLLOWING LINE //OR ELSE THE ROBOT WILL NOT GO forward(); // delay to help jitter/freakouts delay(100); }Some minor changes, adding the PIR and Microphone. Apologies for the lack of documentation on the build. A tip for those geting into it, the seedstudio motor shield seems to pass appropriate voltage to the 'duino, and power the motors from one battery. My fancy-pants wiring harness was at least halfway for naught.
Floz
