Based on the Arduino Leonardo, the Matrix Clock is fully compatible with the Arduino IDE. A coin cell powered DS1307 RTCC keeps track of the time and date when the unit is not powered. The Matrix Clock can also play musical alarms through a piezo speaker. Due to its compact form factor the Matrix clock could be fitted in any number of housings - even a pocket watch style housing. If portability is desirable then the unit can be battery powered and a sleep function is available (by taking one of the expansion pins to ground) in order to extend battery life. I've started designing a range of 3d printed housings and will make the .stl files available as I add more.
Features
- 16x8 LED Matrix display
- ATMEGA32U4 microcontroller
- Coin cell powered Real Time Clock Calendar
- Texas Instruments TLC5920 LED driver
- 4 Buttons
- Piezo speaker output
- Sleep mode input
- 2 power inputs, USB Micro connector or 6V - 9V DC in. (Normal powered by Vin switches when USB power is present).
- Compact form factor
Specifications
| Microcontroller | Atmel ATmega32u4 in TQFP-44 package |
| Operating Voltage | 5V USB powered or 6V to 9V Vin |
| Power and communications | USB Micro B |
| Current | Approx 90mA average during normal operation Max. 300mA |
| LED Matrix | 2x, 8x8, 3mm green LEDs |
| Clock speed | Microcontroller 16MHz, RTCC 32.7KHz |
| SRAM | 2.5 KB |
| EEPROM | 1 KB |
| Flash Memory | 32 KB |
| Expansion Header | Gnd, Vin, 5V, Sleep, Piezo-, Piezo+ |
| Size | 66mm wide x 32mm high x 17mm deep |
| Weight | 30g |
Please check out my web site Carbon Frog for more information about the Matrix Clock and my other projects and products.
danjhamer
jackw01
Dan Hienzsch
makufelis-xyz
This is neat, but you don't mention the the two leds in the middle anywhere? What, how or where?
