While there are many syringe pump designs, the ones I have seen all use a standard medical syringe. This design will be for a syringe that has a body made from PVC piping with ends and plunger made of PLA plastic and built with a 3D printer. The design will be done using FreeCAD and all files will be available on Thingiverse, with the latest versions always on github.
The syringe pump will be driven by a NEMA 17 stepper which will turn an 8mm threaded rod to move the plunger. The idea is that this pump will not be mounted on the 3D printer carriage, but will feed material through a tube to the extruder.
Such a supply system is needed by the two extruders I am developing.
doctek
Joseph Marlin
Johannes Hassler
Oscar S.
Another project of yours that would work well on the Reagent Robot Project.
https://hackaday.io/project/4197-reagent-robot
