Android and USB DAC
01/06/2015 at 21:52 • 0 commentsFound out today that support for USB audio peripherals was added in Android Lollipop. Tested the USB DAC with my Nexus 5 and it worked perfectly! The only downside is that a external power supply is needed when volume is increased.
New DAC/AMP is done!
04/14/2014 at 15:19 • 0 commentsI just finished soldering the components on the latest PCB. Did some testing and everything seems to work. Had some problems with the volume at first, it would change randomly when i got close to the PCB. I think a bad ground connection caused this. The USB-cable i used was very loose in the connector and when i changed the cable everything was fine.
Components and PCB arrived!
04/07/2014 at 16:33 • 0 commentsGot the new PCB and some missing components for the new version today! Unfortunately i could only solder the USB connector before my almost new solder station broke, so now i must get a replacement before i can continue.
Here is the new PCB compared to the old one.
PCB ordered
03/24/2014 at 12:05 • 0 commentsThe PCBs are now ordered from OSH park :)
New PCB layout
03/20/2014 at 13:20 • 0 commentsThe new PCB layout is soon ready :) Only some routing and adjustments left
Updated schematic
03/15/2014 at 16:57 • 0 commentsI am almost done with the new schematic for the (hopefully) final version. The only thing left before i start with the PCB layout is to check all footprints and recheck all connections.
Andreas Dahlberg
