PCB Motor
A smaller and cheaper open source brushless motor
My open source PCB motor is my attempt to build a smaller, cheaper and easier to assemble micro brushless motor.
What unique about this motor design is that the stator is printed on a 4-layer PCB board. The six stator poles are spiral traces wounded in a star configuration. Although these coils produce less torque compared to an iron core stator, the motor is still suitable for high-speed applications.
It also has a 16mm diameter, 1.7mm thin 3d printed 4-pole rotor. So the total thickness of this axial flux motor adds up to 5mm (excluding the shaft) and weighs 1.5 grams.
The inspiration for this idea came from trying to build smaller and cheaper drone. Making the motor onto the PCB itself will reduce the overall price of any tiny robot, allowing swarm robotics to become more affordable.
My PCB-Motor is made from a 6-pole stator printed on a 4-layer PCB and a 4-pole 3d printed rotor. Its has an outer diameter of 16mm and is rated at 1 watt.
I had this idea when I was trying to design a small compact drone. The PCB motor is much cheaper than other micro brushless motors and also easier to assemble. My goal is to make the rotor part of the BOM and mounted just like any other component on a PCB.
VIDEO
HACKADAY SUPERCON DEMO
PCB Motor v3.rar
RAR Archive - 151.40 kB - 06/04/2020 at 20:41
Download
6-layer PCB Motor Gerber Files.rar
Gerber files for my 11mm diameter 6-layer PCB Motor
RAR Archive - 46.53 kB - 11/07/2018 at 16:52
Download
BOM for my PCB motor brushless ESC with Hall sensor feedback
JPEG Image - 59.80 kB - 10/22/2018 at 04:42
Preview
PCB Motor ESC Gerber Files.rar
Open Source Gerber Files for my PCB motor brushless ESC with Hall sensor feedback
RAR Archive - 171.61 kB - 10/20/2018 at 17:47
Download
Open Source Schematics for my PCB motor brushless ESC with Hall sensor feedback
JPEG Image - 61.15 kB - 10/20/2018 at 17:45
Preview
View all 6 files
  • 1 × 3D Printed Rotor
  • 1 × PCB Stator
  • 4 × Magnets (5mm diameter x 1mm thick)
  • 1 × Shaft (1.5mm diameter)
  • 1 × SMF681X-ZZ Bearing
  • FlexPCB Motor + Steel Stiffener Test
    Carl Bugeja • 10/08/2021 at 06:53 • 1 comment
  • Version 4
    Carl Bugeja • 08/05/2021 at 17:36 • 0 comments
  • PCB Motor Wheeled Robot v1
    Carl Bugeja • 05/19/2021 at 12:42 • 0 comments
  • PCB Motor v3
    Carl Bugeja • 06/05/2020 at 16:12 • 1 comment
  • How to design a PCB Motor?
    Carl Bugeja • 04/10/2020 at 13:46 • 0 comments
  • Rotor Flux PCB Motor
    Carl Bugeja • 07/13/2019 at 17:22 • 0 comments
    This video shows my attempt in trying to design a rotor-flux brushless pcb motor prototype:
  • SPEED!
    Carl Bugeja • 06/04/2019 at 00:59 • 0 comments
    How fast can my PCB Motor go?
  • CORE PCB Motor
    Carl Bugeja • 01/07/2019 at 19:06 • 0 comments
    Check out this teardown of the CORE-PCBMotor!! I came across this motor a few months ago, after a few people who saw my design sent me their website's link. There's not much information on it and its also patented but this guy managed to take it apart and review it.
    http://build-its-inprogress.blogspot.com/2018/12/core-outdoor-power-pcb-motor-teardown.html
    I have no idea why they decided to use it for a lawn trimmer (there's much more interesting applications) but its very interesting to see how it was designed, the way the windings are connected and that it has sufficient torque to rotate a blade!
  • Smallest PCB Motor
    Carl Bugeja • 10/31/2018 at 00:11 • 0 comments
    My SUPER tiny 6-layer PCB Motor is spinning! Here's the full video describing how I designed it:
    My original 4-layer PCB motor had a 16mm diameter. By adding two extra layers I was able reduce the number of turns per layer and get it to 11mm. The total height of the motor is 3.6mm and its weight is 0.5 grams.
    No space is lost in this pcb! Each coils have 3 vias to connect the in-between layers. These forced a triangular shaped stator poles, which utilize the magnetic field area more efficiently.
    The tiny rotor design has four press-fit 2mm n52 magnets and a 3mm bearing. This new design has the shaft soldered onto the stator, so it is fixed and don't rotate with the rotor.
    I had chosen to go with this design because of two things:
    1. I couldn't find a bearing small enough to fit in the middle of the stator.
    2.I'm not planning to use a shaft. Customized 3d-printed rotors makes much more sense.
    The phase resistance of this motor was measured to be 15ohmsand its getting to 85℃ with a 4V supply, so it should be perfect for a 1s lipo.
  • ESC details
    Carl Bugeja • 10/20/2018 at 17:52 • 0 comments
    This video shows how i designed my PCB Motor's ESC and what where the challenges involved in getting my speed controller to work.
    This is its schematics:
    It has a PIC16F1503 as the main controller and a triple half bridge driver STSPIN230, to control the three phases of the motor. These are both powered from the same supply, to avoid having an extra power wire or on-board regulator, reducing the cost even further. I filtered the digital circuitry supply from an LC filter to attenuate any noise the motor can generate. It can operate from a 5V to 2.6V supply and draws around 220mA in total.
    As i explained in my previous project logs, the back emf generated from my pcb motor was too weak to implemented a sensorless speed controller. So i decided to use a hall sensor to provide feedback to the microcontroller and then implemented a speed closed loop speed controller.
    The open source gerber files and schematics for this PCB are available for download.
    In the beginning of November I will be giving a demo of this project at the Hackaday Superconference so see you there!
View all 31 project logs
  • 1
    Step 1
    Its this simple:
View all instructions
Hexastorm wrote 11/04/2021 at 15:21 • point
Hey Carl, great project. I am working on prism laser scanner with a BLDC motor see https://hackaday.io/project/21933-prism-laser-scanner .  What kind of weight can you spin with this rotor? How planar is the rotation? The most important requirement is that the prisms stays flat and does not wobble during rotation. The size of the prism, depends on the application.
NccWarp9 wrote 08/27/2021 at 15:16 • point
Have you thought about using SMD inductors as coils? Top of inductors would most probably need to be filed down to expose the core. This would make it possible to increase the power
yueliang1315 wrote 06/02/2021 at 07:39 • point
Good project! and I have also seen a tutorial blog about pcb, maybe you are interesting in it: https://www.nextpcb.com/blog
reginev wrote 03/02/2021 at 14:51 • point
Your PCB is amazing. https://thebestcbdcreams.com/best-cbd-cream-restless-leg-syndrome/
reginev wrote 02/26/2021 at 13:34 • point
Nice work dude. Any tutorial? https://thecbdmagazine.com/cbd-for-asthma/
ogiea wrote 02/26/2021 at 13:09 • point
I am using this when I was in college.
https://thebestcbdcreams.com/best-cbd-cream-for-dry-skin/
Tim E wrote 03/26/2020 at 01:09 • point
I think this motor could change many things in society. Good work!
Tim
https://www.appliancerepairhalifax.com/
Jarrett wrote 11/15/2019 at 00:18 • point
Hey,
For your first 4-layer coil, is there any particular reason you went with the layering order you did?
You go for top->L3->L2->Bottom, just wondering if there was some sort of design reason there
sash wrote 10/12/2019 at 23:23 • point
can u make tutorials on how to make 3d print rotors and stators?thx
sash wrote 10/12/2019 at 22:07 • point
what are the dimensions of the SMF681X-ZZ Bearing. Can you reply sap this is for my science project and i need to use a pcb motor becuase it a cheap and small motor to make. Thank you so much Carl.
albper wrote 04/19/2019 at 14:52 • point
Hi, Carl:
Your  PCB motor is really amaizing.
I think that perhaps you can improved the torque using flex-PBC coil.
Martin Parnell wrote 04/03/2019 at 12:01 • point
hi. I wondered if you could get one of these to spin at much lower RPM. I am in need of this design to build a remote foot switch operated motor to be placed over a volume potentiometer. Specifically for guitar effects pedal.. I believe it is a very sought after use for this sort of motor. Would you like to collaborate in a busines venture? My email is martin.soundman@gmx.com
nokemono wrote 02/18/2019 at 16:49 • point
How did you design this coil?
What is the CAD you used?
ClearloveG wrote 01/24/2019 at 12:40 • point
hello Carl,I  did one of your steps, ESC version.
When I prepared all the devices, I found that I did not have MCU program.
So, I want to say, is this program not open source?
Thanks
anton.fosselius wrote 01/07/2019 at 05:44 • point
Have you seen this: http://build-its-inprogress.blogspot.com/2018/12/core-outdoor-power-pcb-motor-teardown.html
"A company called Core makes some unusual electric lawn tools based on axial flux PCB motors.  I first heard about them several years ago, and finally picked up one of the motors to take apart."
Carl Bugeja wrote 01/07/2019 at 19:09 • point
I just saw the article it very interesting to see how they're designed!
bboyes wrote 01/02/2019 at 04:12 • point
What a great idea! I love how this makes you go to the basics and analyze what really makes a motor and how can you compromise to make a "usable" motor out of unconventional materials? I'd like to try making one of these... I notice the bearing, SMF681X-ZZ, obviously a key component, is about $9 each from Boca bearing. Any idea on lifetime and lowering that cost? Boca doesn't list lifetime data: https://www.bocabearings.com/search?w=SMF681X-ZZ+Bearing
I wonder if this could be adapted to be a low cost local fan for circulating air from a PCB heater.
TinLethax wrote 10/19/2018 at 13:07 • point
Cool project ,Interesting
ep.hobbyiest wrote 10/18/2018 at 05:13 • point
great idea and Awesome project !!!
Michael Graham wrote 10/16/2018 at 23:47 • point
HI Carl, I love your projects, very creative! Just curious if you have experimented with stacking these things?
 You could ~double your torque if you stack a second stator to sandwich ether side of your rotor.  Connect the stators together in parallel with the headers
 The result would still have your nice flat profile (thicker but no diameter change) and it would support the output shaft on either side making it more robust.
 It would prevent you from attatching a fan but the rotor could still be used as a gear/pulley.
majolillo wrote 09/18/2018 at 18:21 • point
Have you considered rebuilding to a switched reluctance motor instead of a bldc? My gut feeling tells me this could be done slightly cheaper and more efficient. What would be required:
- Keep the ferrite sheet in the back
- Ferrite core in each winding
- Replace permanent magnet with reluctance core patterns to match the amount of windings. Probably 3d printed in ferrite, any high permeability low conductive material. A pattern like one that is shown in the end of this video: https://www.youtube.com/watch?v=qDon7Nrj1Tk
As for the required torque, you might want to consider a 3d printed planetary gear
https://www.thingiverse.com/thing:53451
