ESP8266 Dev-Board
Create a development board for ESP8266 with One-Layer PBC and "normal" components.
Third version is ready.
For ESP-01, -03, -07 or -12
Note:
Downloadfiles are to find under "PROJECT LOGS" down
Development Board ESP8266-01 Version 1:
1. Regulated Power
2. Status LED
3. Reset Button
4. Pin´s for programing ESP8266
5. Switch between RW and FLASH-Mode
Development Board ESP8266-01 Version 2:
1. Regulated Power
2. Status LED (Power, Gpio 0, Flash, RW)
3. Reset Button
4. Pin´s for debug programing ESP8266
5. Pin´s for debug or scope Gpio 0 / 2
6. Switch between RW and FLASH-Mode
7. On-Board-Programer (CP2102)
Development Board ESP8266-01 Version 3:
1. Regulated Power
3. Reset Button
4. IO-Pins for ESP-01 & ESP-03 & ESP-07
5. Shield for ESP-03 & ESP-07 (& ESP-12 optional)
8. Levelshifter
9. Pinlayout for ESP-01 & ESP-03 & ESP-07 & ESP-12 programming
5.
Upload .ino-files: youtube
4.
Board Wiring: youtube + Arduino file: Knight Rider Test
3.
Shield Pinlayout: youtube
2.
Dev Board V3 ready.
1.
Version 2 is ready.
Eagle files with parts for downloading, look :
Project logs
Note:
The USB-TO-TTL Programer is unter the LM2596S. See picture.
I dissemble a CP2102 converter and solder it on PBC.
The USB connerctors from CP2102 are solder togethereith copper survace and connects an SMD Mini USB female connector ( in picure on the left).
This is not nessesary, but easy to get an fast development with ESP8266.
Think the PBC will get much more smaller without programer on board.
The third version will come in April 2015.
  • 1 × ESP8266 ESP-01 Board in V1 & V2 , + in V3 ESP-03 & ESP-07
  • 1 × USB-TO-TTL Programer CP2102
  • 1 × Eagle designed Basic Board one layer PCB
  • 1 × Standard parts 2,54 mm Power plug, Resistor, Led, Pinheader, Push button,
  • 1 × Bug converter 3,3 V LM2596S
View all 8 components
View all 7 project logs
Rich text editor
Hans Reimersen wrote 06/06/2015 at 06:00 point
Meinen Glückwunsch zu dieser Idee. Da ich von diesem Projekt begeistert war, habe ich mal versucht es nachzubauen. Leider funktioniert es bei mir nicht. Problem ist folgendes: Ich habe aus Eagle heraus das Layout für das DEV Board V3 gespiegelt gedruckt. Auf eine Platine übertragen und geätzt, soweit so gut. Nun zum ersten Problem: Beim Levelshifter sollen 5 V vom CP auf der Seite HV reingehen und bei LV sollen 3V raus kommen. ( Wenn ich das richtig verstanden habe) Bei mir kommen da aber keine 3 V raus sonder nichts, somit ist natürlich die ganze Stromversorgung nicht gegeben. Bei dem von mir hier vorliegenden Levelshifter kann ich auf der LV Seite 5 Volt rein geben und auf der HV Seite kommen dann 2,5V raus. Also habe ich mir gedacht ich spiegele das Layout mal nicht und habe eine neue Platine geätzt. Nun passt das zwar und beim PIN wo der ESP01 z.B. eingesteckt wird, kommen auch 3,3 Volt an, jedoch geht der ESP nicht an. Also leider weis ich hier nicht weiter, was oder wo kann der Fehler sein? Auf deinem Schaltplan ist auch der LM2506S eingezeichnet, denke das dieser aber für eine andere Versionen des Boards ist.
Schade das es nicht geht, vielleicht hast du aber auch  einen Tipp für mich wo mein Fehler evtl. ist. Was ich auch nicht verstehe ist, was versorgt eigentlich der Power Conector, außer die LEDS?
Mit google übersetzt in der Hoffnung du kannst deutsch :-)
With Google translated hoping you can German :-)
Congratulations to this idea. I was excited about this project, I once tried to recreate. Unfortunately it does not work with me. Problem is this: I have printed out from Eagle layout of the Development Board V3 mirrored. Applied to a board and etched, so far so good. Now for the first problem: When level shifter to 5V by the CP to go in on the HV side and LV are at 3V come out. (If I have understood correctly) with me to come there but not 3 V out special nothing, therefore all power is of course not given. In the level shifter present from me here I can on the LV side give 5 volts in and on the HV side come out then 2.5V. So I thought I did not reflect the layout of times and have etched a new board. Now that matches indeed and the PIN where the ESP01 example is inserted, and 3.3 volts to come, but the ESP does not turn on. So unfortunately I know of no further, what or where can be the error? On your circuit diagram and the LM2506S is located, but think that this for an other versions of the board is..
Too bad that does not work there, maybe you have but also nich a tip for me where my mistake is possibly. What I do not understand what is actually supplied the Power Conector except the LEDS?
davedarko wrote 06/06/2015 at 07:15 point
Hey Hans, ich glaube es wäre recht hilfreich, wenn du eine Seite auf deinem Profil erstellen könntest und dann ein paar Bilder deiner Platinen postests, dass er sich das mal angucken kann.
Hey Hans, it probably would be helpful if you could add a page on your profile with some pictures of your boards, so he can take a look at it.
Gruß aus Berlin
Hans Reimersen wrote 06/06/2015 at 10:08 point
Danke für den Tipp davedarko. Weis leider nicht wie ich das machen kann. Hab bis her in meinem Profil nur eine Möglichkeit Bilder hochzuladen gefunden und das ist unter Projekt. Denke aber wenn ich da was hochlade, wird das hier doch für alle veröffentlicht oder?
Grüsse zurück in unsere Hauptsadt
Chris Wagner wrote 06/06/2015 at 15:53 point
Hallo zusammen,
ja ich kann deutsch :D Yipii.
Ich weiß wo das Problem ungefähr liegt. Ich mache dazu ein Video und hoffe es hilft dein Problem zu lösen.
Googel Translate:
Hello everybody,
I know what the problem is about . I make to a video and I hope it will help to solve your problem .
Have a nice day,
nice regards from Dortmund.
Hans Reimersen wrote 06/06/2015 at 17:31 point
Nen BVBler das macht dich bei mir noch sympathischer :-) Das ist natürlich absolute Klasse von dir, dass du das Video machst. Weil echt das Projekt ist das Interessanteste was ich für den ESP gefunden habe und ich möchte dein DEV Board unbedingt haben.
Danke!!!
Chris Wagner wrote 06/07/2015 at 12:00 point
Danke, da hört man immer gerne. Ich nutze das Board um meine
Studienarbeit voranzutreiben. Und natürlich eine "simple" Plattform zu
haben, um den Chip zu programmieren.
Das Video ist soweit fertig, leider ohne sprache, aber dafür mit Text.
Du findest es oben oder unter:
Ich hoffe du kannst damit was anfangen. Ich werde die Readme.txt auch aktualiesieren.
Translate:
Thank you, nice to hear that. I use the board in order to advance my study
work . And of course,  to have a "simple " platform to program the chip .
The video is ready so far , unfortunately without language , but with text .
You can find it in top of this massage.
I hope I can answer your question . I will also update the Readme.txt .
Have a nice and sunny day.
Hans Reimersen wrote 06/07/2015 at 18:24 point
Danke!! Ich schaue mir das noch mal in Ruhe an und werde die Readme Datei lesen. Ich bin nicht so der grösste Elektrofreak, aber wenn ich was nicht verstehe, dann habe ich einen Freund der mir immer gerne hilft, den werde ich dann zu rate ziehen. Dir wünsche ich bei der Studienarbeit viel Glück und Erfolg. Ich melde mich auf jeden Fall hier zurück, erfolgreich oder nicht.
Beste Grüsse
aus der nähe von Hannover :-)
