1Step 1
- (Optional, but recommended): Burn the FinalKey modified bootloader to the Pro-Micro using an ISP.
- Solder EEPROM to Arduino
- Solder Pullups to Arduino
- Solder LED to Arduino
- Solder Button to Arduino
- Place in case
- Seal with hotglue - This is not tamper protection, but for mechanical stability/durability, the hotsnot holds up well for this, but you can use something more toxic if you desire.
DusteD
