GitHub repository created + PCB layout rev0 added to gallery
04/10/2015 at 16:17 • 0 commentsHey there,
quick update to report that I finally added revision 0 of the PCB layout to the project gallery. I also created a github repo to store the EAGLE project files.
Cheers.
Mick
EDIT: my company policies won't allow push requests from my git client to the server, so I'll sync the first commit when I get back home.
Everything setup except for correct voltage output of sync lines
04/07/2015 at 12:36 • 0 commentsThe layout of the board is finished, I can't upload it right now because I got that on a different PC. The only thing I'm missing (which is also missing from the original schematic) is correcting the output voltage of the sync lines to a proper TV-acceptable signal. Any suggestion? I'm posting this on the stack as well.
Michele Perla
