1Step 1
These instructions are pretty coarse, but I think you'll get the idea.
Two square pieces of plywood and some screws hold the tube that is attached to the vacuum cleaner. They are attached to the lid, one on the inside and one on the outside:
2Step 2
The inlet is built in a similar way.
A piece of PVC pipe is prepared with some slots to allow clamping of the inlet tube:
The pipe is held by two square pieces of plywood, four screws and a 90 degree bend is attached on the inner barrel side:
I also sealed the inlet with some silicone, but if that is necessary depends on the build.
3Step 3
Um, yeah, that's it.
Christoph
