LIR2450 USB Charger
Charge LIR2450 coin cells over USB
UPDATE: Charging works, LEDs do not.
I started doing a lot with low power devices (Arduino, BLE 4.0) and coin cells are a convenient power source. Lately I found out that there are even rechargeable coin cells. That's why I needed a charger. There are only a few models out there which were either expensive or I didn't trust the charge current (too high). So I made my own.
It is based on the MCP73831. Order three PCBs for 13.60$ at OSHPARK: https://oshpark.com/projects/roORU8h6
There are two charge modes:
- fast (45mA)
- slow (25mA)
Max charge current for a coin cell is usually between 80% and two third of it's capacity. So you could charge a 100mA coin cell with 80mA. I wanted to increase the lifetime of my coin cells and reduced the charge current. If you want to have different currents here is the equation to calculate R_SLOW/R_FAST:
mA = 1000 / R in kΩ
Example: 1000/20kΩ
  • 1 × MCP73831 SOT23-5 Power Management ICs / Power Supply Support
  • 1 × 0603 LED Green (3.1V voltage drop)
  • 1 × 0603 LED Orange (2V voltage drop)
  • 1 × 0805 Resistor 200Ω
  • 1 × 0805 Resistor 320Ω
View all 11 components
Chris wrote 09/10/2015 at 12:25 • point
Forgot to update it here: The circuit is charging the coin cell but the led indicator does not work. I am not sure if it's because I got a cheap chip from Aliexpress or what else ... The circuit is almost the exact copy of the reference implementation from the data sheet. The  charging LED is on all the time and does not turn off. However the chip is charging correctly. Once the cell is full the amperage going to the cell is almost zero.
davedarko wrote 09/10/2015 at 13:35 • point
thanks for the quick reply! I'll see what my chinese clones will do :)
Alex wrote 09/10/2015 at 13:59 • point
the ICs (probably also china-clones)  I did get do work fine (with normal lipo- batteries). And also the charge LED is going off if ready
davedarko wrote 09/10/2015 at 14:05 • point
the datasheet said LOW when charging and HIGH when done, hmm...
Alex wrote 09/10/2015 at 15:08 • point
When you use an led between VDD and STAT, the led is on when charging.
davedarko wrote 09/10/2015 at 15:15 • point
Aahh, I thought your chip was putting it out differently from what you expected... makes sense now.
davedarko wrote 09/10/2015 at 12:11 • point
so, does it work? because I've copied your design (checked back with the datasheet as well) for a LIR2032 and was wondering about any updates.
jaromir.sukuba wrote 09/10/2015 at 13:51 • point
There is nothing in this circuit that shouldn't work. It is basic circuit from MCP73831 datasheet, as per manufacturers recommendation; I used it in a few projects before, some of them are here on HaD.io
davedarko wrote 09/10/2015 at 14:04 • point
That was actually me trying to bring someone to update his project ;) I started with the datasheet as well but got the idea here. Later I compared the resistor values with his and took the formula from above to get values for a standard 2032 version.
