CC3200 to the rescue!
01/06/2016 at 15:13 • 0 commentsI managed to the the Xively C client running on the TI CC3200 Launch-XL module.
This is going to be the perfect platform for the new boiler monitor using Xively.
I will be able to publish temperatures and even (if I want to) subscribe to channels so I could control the boiler remotely.
Also, Jeff gave me a board with five Opto-22 input modules, so I'll get those hooked up to monitor the three "call-for'heat" signals and the gas-valve-open signals so I can publish those along with the temperature data.
I'll need to look into the analog inputs on the CC3200 or build an A/D and connect it Nothing too difficult.
This is very exciting.
New job!
03/07/2015 at 16:51 • 0 commentsI just took a job at an actual Internet Of Things company (Xively), so I'll soon be replacing this with an actual professional IOT system. I'll keep this project log updated as I learn how to use the professional toys. -
Remaining problem
02/14/2015 at 20:43 • 0 commentsSometimes the system stops sending data to sparkfun.
If I reset the Arduino it doesn't help.
If I power-cycle the Linksys running DD-WRT, it comes back, so there's something wrong over there.
I think I'll change to using a WiFi shield now that I know what I'm doing and get rid of the Linksys/DD-WRT altogether.
Here's the Arduino code to read 6 TMP036 sensors, average them and push them up to data.sparkfun.com
02/14/2015 at 20:40 • 0 commentsHere's the code for my Arduino MEGA2560 and whatever Ethernet shield I got.
It came from sparkfun's example page and I just added reading the six analog inputs, averaging several samples and converting to degree-F before pushing the data to sparkfun.
/***************************************************************** Phant_Ethernet.ino Post data to SparkFun's data stream server system (phant) using an Arduino and an Ethernet Shield. Jim Lindblom @ SparkFun Electronics Original Creation Date: July 3, 2014 This sketch uses an Arduino Uno to POST sensor readings to SparkFun's data logging streams (http://data.sparkfun.com). A post will be initiated whenever pin 3 is connected to ground. Before uploading this sketch, there are a number of global vars that need adjusting: 1. Ethernet Stuff: Fill in your desired MAC and a static IP, even if you're planning on having DCHP fill your IP in for you. The static IP is only used as a fallback, if DHCP doesn't work. 2. Phant Stuff: Fill in your data stream's public, private, and data keys before uploading! Development environment specifics: IDE: Arduino 1.0.5 Hardware Platform: RedBoard & PoEthernet Shield This code is beerware; if you see me (or any other SparkFun employee) at the local, and you've found our code helpful, please buy us a round! Much of this code is largely based on David Mellis' WebClient example in the Ethernet library. Distributed as-is; no warranty is given. *****************************************************************/ #include <SPI.h> // Required to use Ethernet #include <EthernetV2_0.h> // The Ethernet library includes the client /////////////////////// // Ethernet Settings // /////////////////////// // Enter a MAC address for your controller below. byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // if you don't want to use DNS (and reduce your sketch size) // use the numeric IP instead of the name for the server: //IPAddress server(54,86,132,254); // numeric IP for data.sparkfun.com char server[] = "data.sparkfun.com"; // name address for data.sparkFun (using DNS) // Set the static IP address to use if the DHCP fails to assign IPAddress ip(192,168,2,200); // Initialize the Ethernet client library // with the IP address and port of the server // that you want to connect to (port 80 is default for HTTP): EthernetClient client; ///////////////// // Phant Stuff // ///////////////// const String publicKey = "YOURPUBLIKKEY"; const String privateKey = "YOURPRIVATEKEY"; const byte NUM_FIELDS = 6; const String fieldNames[NUM_FIELDS] = {"boilerout", "boilerreturn", "zone2out", "zone2return", "zone3out", "zone3return"}; String fieldData[NUM_FIELDS]; #define BOILEROUT 0 #define BOILERRETURN 1 #define ZONE2OUT 2 #define ZONE2RETURN 3 #define ZONE3OUT 4 #define ZONE3RETURN 5 #define LEDPIN 13 ////////////////////// // Input Pins, Misc // ////////////////////// #define SDCARD_CS 4 bool print = 0; void setup() { // Set Up Ethernet: // start serial port: Serial.begin(9600); pinMode(SDCARD_CS,OUTPUT); pinMode(0, INPUT); pinMode(1, INPUT); pinMode(2, INPUT); pinMode(3, INPUT); pinMode(4, INPUT); pinMode(5, INPUT); pinMode(LEDPIN, OUTPUT); digitalWrite(SDCARD_CS,HIGH);//Deselect the SD card // give the ethernet module time to boot up: delay(1000); // start the Ethernet connection: if (Ethernet.begin(mac) == 0) { if(print) Serial.println("Failed to configure Ethernet using DHCP"); } Serial.println(F("=========== Ready to Stream ===========")); } void loop() { int i,j; float temps[NUM_FIELDS][10]; float average[NUM_FIELDS]; char buffer[80]; // Buffer to convert from binary to ASCII // Read each sensor ten times at a rate of 1 Hz. THis takes (10 times NUM_SAFIELDS) in seconds (60 for this example) for(i=0;i<10;i++) { for(j=8;j<8+NUM_FIELDS;j++) { analogRead(j); delay(10); analogRead(j); delay(10); temps[j-8][i] = ((((analogRead(j) * 5.0) / 1024.0) - 0.5) * 100 * 9.0 / 5.0) + 32.0; if(print) Serial.print(j-8); if(print) Serial.print(" ");if(print) Serial.println(temps[j-8][i]); delay(166); } } // Calculate the sum of the last ten samples for(j=0;j<NUM_FIELDS;j++) { average[j] = 0.0; } for(i=0;i<10;i++) { for(j=0;j<NUM_FIELDS;j++) { average[j] += temps[j][i]; } } // Calculate the average of the samples and fill in the output fieldData array for(j=0;j<NUM_FIELDS;j++) { fieldData[j] = dtostrf(average[j] / 10.0, 3, 1, buffer); if(print) Serial.print(fieldData[j]); if(print) Serial.print(" "); } if(print) Serial.println(); digitalWrite(LEDPIN, HIGH); if(print) Serial.println("Posting!"); postData(); // the postData() function does all the work digitalWrite(LEDPIN, LOW); } void postData() { // Make a TCP connection to remote host if (client.connect(server, 80)) { // Post the data! Request should look a little something like: // GET /input/publicKey?private_key=privateKey&light=1024&switch=0&name=Jim HTTP/1.1\n // Host: data.sparkfun.com\n // Connection: close\n // \n client.print("GET /input/"); client.print(publicKey); client.print("?private_key="); client.print(privateKey); for (int i=0; i<NUM_FIELDS; i++) { client.print("&"); client.print(fieldNames[i]); client.print("="); client.print(fieldData[i]); } client.println(" HTTP/1.1"); client.print("Host: "); client.println(server); client.println("Connection: close"); client.println(); } else { if(print) Serial.println(F("Connection failed")); } // Check for a response from the server, and route it // out the serial port. while (client.connected()) { if ( client.available() ) { char c = client.read(); if(1) Serial.print(c); } } if(1) Serial.println(); client.stop(); } void setupEthernet() { if(print) Serial.println("Setting up Ethernet..."); // start the Ethernet connection: if (Ethernet.begin(mac) == 0) { if(print) Serial.println(F("Failed to configure Ethernet using DHCP")); // no point in carrying on, so do nothing forevermore: // try to congifure using IP address instead of DHCP: Ethernet.begin(mac, ip); } if(print) Serial.print("My IP address: "); if(print) Serial.println(Ethernet.localIP()); // give the Ethernet shield a second to initialize: delay(1000); }
How to graph the data?
02/10/2015 at 18:04 • 0 commentsLooking around for sparkfun IOT chart, I found that imp.guru can grab and plot data from sparkfun if you just hand over the public keys!
So I have imp.guru/f48 showing live data. NICE!
But I wanted to make charts with Input and Output temperatures together, I stumbled onto phant.io http://phant.io/graphing/google/2014/07/07/graphing-data/ where they describe how to use google charts to plot data.
I took a few hours and got charts! http://bobodyne.com/boiler
I'm pretty happy that I can look at the boiler, show other engineers what's going on and keep track of things.
I want to add temp sensors on zone #1 (Basement) and maybe an outside air temperature also.
Where to push the data?
02/10/2015 at 17:59 • 0 commentsI looked at Exosite.com to see if I could use their service for free for a while and didn't get it working with their Arduino examples.
It turns out that there are two different Ethernet shields/libraries and the Exosite examples were for the other one.
But I did find that sparkfun has a data service and Arduino examples at data.sparkfun.com and I was running almost immediately.
