Fixing 2 layer pins
08/31/2015 at 00:07 • 0 commentsSomehow, I reversed the i2c pins on the 2 layer. So I will fix that before selling them. I still can't decide if the 2 layer or slightly smaller 4 layer design is better.
2 layer success
08/17/2015 at 17:03 • 0 commentsWe have found better performance in 2 layers, though the 4 layer boards do work OK. We might be able to determine the 4 layer issues, but I think it might come down to quality of solder mask. The 9 axis has some tiny pads, and for some reason the 4 layer quality just isn't there.
Still having problems
07/19/2015 at 09:38 • 0 commentsI think having 4 layers has complicated things. I am having serious issues communicating with the chips. So I am reducing the layers, spreading the chips further apart, and minimizing the amount of traces under the components. I hope to see a serious improvement.
Update Solder Bridges/i2c
02/18/2015 at 17:20 • 0 commentsIncreasing size for easy hand soldering. Rearranged i2c bus similar to other Flex Module designs.
Quick design
02/12/2015 at 00:09 • 0 commentsSimilar to the original 10-axis design. I have already sent the boards to be made by OSHPark.
Chris Hamilton
