13D print
PLA 0.2mm layer height. Infill 95%.
2Socket pads
Shape the pads and install them in the battery socket.
3Battery connector
Glue the battery connector to the battery case.
4Shape the battery case
Cut the case with the hack saw until you happy with the over hall shape of the assembly.
5Soldering
Solder the pads of the socket with the connector "the positive to the positive" and "negative to the negative"
6Insulation
Insulate electrically the solder joints with some rubber.
7Glue up
Glue the both half together
NPN
