Basically, you need to build the USB-ST4 interface described in the github project page and modify your control pad like explained here if it doesn't have an ST4 port.
Modifying the control pad means soldering and wiring an RJ12 socket to the pad buttons.
Once the hardware is done, you will need to install the ASCOM platform and the driver.
After this you can use a software like the open source stellarium to play with your telescope or PHD for astrophotography.
More details are available on the github project page.
Here is a small guide to use it with stellarium.
Sample video of the telescope moving:
ken.do
Embedotronics
atomkemp
Michael
Thank you for responding so fast is that your connection pins are not polarity-standard st4 and as new engines Enhanced Skywatcher Dual-Axis Motor Drive and the port st4 bienen Interface Autoguider I would not do a bad connection and damage relay box.
Find out how to change the pin assignment in the Arduino code,
since I'm not very good with this programming thank you very much again when you have it working I will comment thanks
